Author Topic: Lister CD - New life, from grain thresher to show off piece.  (Read 65133 times)
sirpedrosa
Re: Lister CD - New life, from grain thresher to show off piece.
« Reply #30 on: March 06, 2025, 12:25:56 AM »
AdeV,
Indeed!
But there some pics (above) that the thumbnail now is horizontal because I edited the image and rotated it -90º, and so when you click it the resize will show it as I intended to be seen.
I mean I cheated the resize tool in order the pic be shown "right".
See below pic showed with the hint on original, and after in the one edited.
VP
By order:
Petter PAZ1 - Jun 1967, 3HP, sn 416xx
Petter PAZ1 - Nov 1979, 425xx [Kristin gen]
Lister CD [355399] 1937 - on the bench..
sirpedrosa
Gentles,
More than 150 days,  in 4 mouths, of rain makes everything idle here.
A few roof edge tiles fell down with Martin's storm.
Meanwhile, a few more bits off the Lister CD. All wheels of kart are finally off.
And a new  ;D ;D (2nd hand from 80's) field cultivator to my micro farm.
2 pics to the rant.
VP
By order:
« Reply #32 on: April 04, 2025, 06:08:01 PM »
AdeV,
Indeed!
VP
Hey VP - apologies, I didn't reply to you (been v. busy...)
I think, in order for the thumbnail/main image to display in the same orientation regardless of how you rotate it, you need to make sure you save it without any EXIF data. The EXIF data (which most image editors preserve) tells the display device what orientation the camera was in when you took the photo. So where you've rotated the image, the display device (computer) sees that the EXIF data says "rotate 90", and it rotates it... and now it's "wrong". Equally, I'm not sure that the software that generates the thumbnails for the site honours the EXIF data (I'd actually be surprised if it did), which would explain why the thumbnail is portrait but the image is landscape, or vice versa...
All I can suggest is, when you modify a photo for the site; find & de-select the option to save EXIF data. e.g. for gIMP (the defacto standard Linux image editor), when you export a file, the options dialog that pops up has "Save EXIF data" checked by default - un-check it and the photo will appear how YOU want it, and not how the computer thinks it should be.
sirpedrosa
AdeV, Gentles
Many thanks for your time, and stubbornness (bien entendu!).
The catch is: Before was all ok! why change what was ok? (nº 1 rule of computer science engineering - my humble degree).
But, I can see you are at Linux (was there 20 years ago), so Ill follow your lead. 1st rule here is to share good info with our forum members.
Keep the good work! Covid took us a few Master minds of stationary engines.
VP
By order:
sirpedrosa
Gentles,
The toy is going slowly.
Today managed to drill and tap M5 hole to put a set screw in order to prevent or stop(??) the bearing to spin inside its housing.
Remember I pulled easily the bearing?
Lets see how it goes.
This trick was - once again - one advice of my friend Mr. Pedro, from VEICOMER (https://listerengine.com/smf/index.php?topic=9555.msg111186#msg111186)
A pic to showoff.
VP
PS: image without properties still rotate.
« Last Edit: April 05, 2025, 06:04:17 PM by sirpedrosa »
By order:
sirpedrosa
Gentles,
Another trick to pull off crank pinion.
Got to make extenders to my ugly puller. It ends perfect as I wanted.
Pulled out woodruff key too.
Now got to take out long head studs that goes from top to bottom.
A few pic to the show.
VP
PS: I give up! even pulling out EXIF data, no joy to show the straight pic.
« Last Edit: April 12, 2025, 01:13:44 PM by sirpedrosa »
By order:
sirpedrosa
Gentles,
While raining outside and after supper, give a few more kicks in the CD.
Flipped to side, finally toke oil pump off, after that the sump - take a look at that gunk and slurry!
Pull out long head studs and crank after that.
Intermediate gear of oil pump too, and crankcase support brackets.
Almost all stripped. Next task pull off compression operating shaft.
A few pic to showoff.
VP
PS: Please can anyone tell me why crank casting date - following Lister's mode of dating cast iron - shows 15JAN1920, but CD only start to be made at 1933.
« Last Edit: April 12, 2025, 04:21:34 PM by sirpedrosa »
By order:
sirpedrosa
Gentles,
The CD is almost striped and so some bits already got one hand of primary paint.
In the other hand started to search for some parts: Rocker bushes, crank oil seals, governor bearing.
Made an inquiry about main bush bearings, and valve guides, but nothing so far.
Meanwhile, start to prepare bits and store in baskets.
Push out the crank oil seals, and surprise - at anytime of engine life they put a metric oil seal, hence why they have a wrap of tin foil, because casing is imperial (2.3/8x3.3/8x1/2). But you can see they put in M 60x85x12.
A few pics to the show.
Cheers.
VP
« Last Edit: April 14, 2025, 10:09:10 PM by sirpedrosa »
By order:
According to my image editor (GIMP - Gnu Image Manipulation Program, on Linux) - the images still have EXIF data in them...
What photo tool are you using to edit them with?
Can't answer your Q on the cast iron date.... maybe they mis-stamped it? But that seems unlikely, somehow. I'm pretty sure the CD doesn't share any castings with older engines.
sirpedrosa
Gentles, AdeV
I use MS Picture manager with win7 64.
Giving one more push to the CD, today put my eye in the oil pump.
But going back a few days ago I was suspicious about the shape of pinion teeth. They seem to have chewed "something" at any time of its life.
Looking at the intermediate oil pump pinion, and the oil pump pinion it self, for sure something got to be there between the teeths.
And also I noticed the pump pinion was wobbling on its spindle, and take out the tapered key. Take a look at it. Just incredible!
Take a look too to the oil pump wheels teeth's shape and you can imagine how many thousands of hours it has.
VP
By order:
sirpedrosa
Lister CD - Iron down to rebuild
« Reply #40 on: April 25, 2025, 03:26:35 AM »
Gentles,
The kart is free of the CD.
All iron is downtown to start rebuild.
Last bit of crankcase was the liner, and it ends up to be a smooth operation.
A few pics to show off.
VP
By order:
sirpedrosa
Lister CD - New life, from grain thresher to show off piece. Primary on!
« Reply #41 on: April 26, 2025, 02:12:01 PM »
Gentles,
Things are going smoothly, and after a good cleaning and pressure washer big stuff is getting his hand of primary.
Crankcase, crankcase bracket, head and pulley.
2 pic to the show.
VP
By order:
sirpedrosa
Gentles,
The CD got it kart to move side to side to be erected.
Passed tap on threads to tuning them.
Found some sand pockets in the crankcase... ence they paint it with filler.
Give a very fine paper sand (2000 and 5000) at big end.
And found a original stamp on top of crankcase.
A dew pics to the show.
VP
By order:
sirpedrosa
Gentles,
Another rainy day!
Went to get injection pump and the injector from Bosch lab. This time payed only with friendship.
Sorting bits from basket, had take measure to the small end bush, and it indicates about 0,15 mm of lash on vertical axis. Let's see if new bush will be needed.
2 pics to the show.
VP
By order:
sirpedrosa
Gentles,
The CD is coming up.
A few bits arrive from GB... at gold price. Carriage, plus tarifs tripled the final price.
The MBG is giving nice color to major bits.
2 pics to show.
VP
« Last Edit: May 18, 2025, 01:16:34 PM by sirpedrosa »
By order:
