I am replacing valve guides on my stock 12/1 Lovson listeroid. I have seen some posts on here about valve guides especially about lubrication (splash and splash with holes in the guides). The valves that I am replacing have the lubrication hole just within the recess of the lubricant well directly under the springs. The intake and exhaust are about 3/16 different in total length (3-1/16 and 3-1/4) and protrude at the bottom into the chamber about 3/8th of an inch each. The ones that I have in one of my rebuild kits from I think from central Maine diesel dont have the lube holes and are longer in length (3-5/8 and 4-1/4). The new ones would protrude into the chambers roughly 1/2 longer on the intake and 3/4 on the exhaust. The exhaust is also bored out about 3/4 of a of an inch on the bottom side beyond where the valve slides.The new ones also will be protruding from the seat roughly 1/8 more on the intake and 1/4 on the exhaust. I will attempt to send a photo. They seem to want to easily slide in to be pressed.
But what I am asking, of course, is this variant common and will these replacements be an issue? Has anybody run into this with the commonly available set of valve guides or is there a supplier of valve guides closer to original that I need to find?
