I have a second hand ST2 lister generator, 6kVA. I routinely start it with a starting handle but it comes with the option of starting via motoring the generator under decompression (I have been using a 12V car battery although I noticed online that others seem to use a pair of batteries giving 24V).
My knowledge of electronics is very rudimentary, but when I bought it, I upgraded some of the supply wiring in the top box, replaced the absent starter relay, added trip switches to the live outputs, and added an hour meter. I used it regularly for many months with this arrangement without issue.
However, a few months ago I began to notice that, after switching on the power after the generator had reached full speed, the voltage appeared to ramp up from nothing and take a few seconds to reach its normal operating output (lights increasing from off to dim to full brightness). This continued to worsen until no power would be produced if I did not first flash the generator by motoring it using the push start and battery arrangement under decompression. (I took this to mean that residual magnetism was being lost after every use, despite no change in operation and removing the load before shutdown.) This proved adequate, if not ideal, and I used it in this way for several more months.
However, this practice no longer seems to be working as despite using the battery to motor the generator first, the voltage output remains unusably low (the outside LED strip lights I routinely switched on first to test now flicker or do not light). It was working adequately the day before.
I investigated for a source of the problem among the wiring I was familiar with, and everything seems intact. However, I am no expert and there are several components that I do not recognise and have no knowledge of. I have photographed these and labelled them A-E. It is the first time I have removed the side panels.
Image 1 left panel components (I do not know what these are, and although all wiring is intact and secure, it would appear that the component marked B is damaged?)
Image 2 component B up close
Image 3 top box with components C and D. Component D shows evidence of heating (dark area) and I do not know if this is normal.
Image 4 right panel component E. I believe this is a rheostat and see no obvious fault with it.
Image 5 - view of brushes and associated wiring from right
Image 6 - view of brushes and associated wiring from left
I would be grateful if you could outline what the components are and suggest or identify a likely problem with any of them from what you can see. If you suggest replacing any of them with their modern counterparts, details of the specifications and exact wiring guidance would be appreciated.
Many thanks,
Matthew
Unfortunately it is not letting me attach any photos - try the link below or contact me privately if you can help. Thanks.
https://drive.google.com/file/d/1cSaeVwzhgLZ5HjchoS4kJpvE3WS9-53Z/view?usp=drive_link
