Hi All!
I have a Winget Dumper fitted with a Lister D2 Engine.
I have done a service on it by replacing the fuel filter, oil filter and changed the oil. I also replaced the gasket seals on the rocker covers.
I am learning about these engines as I go and so far so good, but upon inspecting for any fuel leaks I started the engine with the fuel pump housing cover off and noticed some oil dripping in and around the fuel pumps and down through the drain holes in the fuel pump housing into the oil sump. Is this normal? I can’t see any fuel leaks from the fuel pumps or from the injectors.
I assume there should be oil ‘washing’ the components to keep them lubricated, as that’s why the rocker covers and fuel pump housing covers have seals on them. How much oil should draining through the fuel pump case back into the sump usually? How much oil should be under the rocker covers and fuel pump housing?
Thanks for any help!
Robin
