Author Topic: SL4 SL rack  (Read 25965 times)
KC7NOA
Re: SL4 SL rack
« Reply #30 on: October 01, 2024, 10:27:50 PM »
i got impatient .. and tore it up a bit ...
KC7NOA
Re: SL4 SL rack
« Reply #31 on: October 07, 2024, 01:21:58 AM »
Last 2 to do ...
KC7NOA
Re: SL4 SL rack
« Reply #32 on: October 07, 2024, 01:22:59 AM »
I'd plate
KC7NOA
Re: SL4 SL rack
« Reply #33 on: October 10, 2024, 06:14:41 AM »
I had let them cure for 2 days ... well 2-1/2 days and the wax paper peeled off nicely
KC7NOA
Re: SL4 SL rack
« Reply #34 on: October 11, 2024, 02:08:44 AM »
This belt is about 1" short or so ...
I got it on but it was kinda tough ...
I'll post a picture when I can ... don't know why I'm failing checks again
« Last Edit: October 11, 2024, 03:34:28 AM by KC7NOA »
KC7NOA
Re: SL4 SL rack
« Reply #35 on: October 12, 2024, 06:29:57 PM »
Anyone have experience with slr4 air ducting?
« Last Edit: October 12, 2024, 06:48:44 PM by KC7NOA »
KC7NOA
Re: SL4 SL rack
« Reply #36 on: October 17, 2024, 06:46:23 PM »
how much can a head bolt be rusted before its suspect?
KC7NOA
Re: SL4 SL rack
« Reply #37 on: April 03, 2025, 04:41:39 AM »
What I mean is that I see a bolt that it about half way rusted through and I'm wondering if it's now compromised and even worse might break when trying to remove/replace it
dax021
Re: SL4 SL rack
« Reply #38 on: April 03, 2025, 02:59:24 PM »
IMHO, it sounds compromised.  Seeing as you have the engine apart, I would try replace it at this stage.  It would be a mission if it breaks off during assembly, as that would mean stripping again, and you would still have to remove the broken stud.
KC7NOA
Re: SL4 SL rack
« Reply #39 on: April 03, 2025, 05:20:29 PM »
the motor is not taken apart yet,
iv just got it running last fall, then went on to remove what was left of the air cooling duct .. it was half rusted away
and when that was finally removed i was abit shocked to see a head/sleeve bold looking half rusted away ...
i was looking for a leak , call it like a bubbling sound after the motor was stopped.
im planning on getting back to working on the motor since the snow has melted and all ...
im wondering if there are USA sources or if ebay or old timer engines is my source for a short head bolt
