How to / DIY > Engines
Push rod seals
jddevel:
My first post and hopefully like other forums of which I am a member it will be a never ending source of great advice. So my first question. I`ve purchased a Benford dumper with a 3 cylinder Lister. My first problem is a serious leak from the centre pots push rod. So what is the best approach to repairing the situation please. I am reasonably mechanically minded. Thank you in anticipation.
dax021:
The first thing you need to do is post as many pictures as you can of the engine, including serial plates and the leak. That way the experts on this forum (I am not one of them) can determine the best way forward relevant to your particular model.
jddevel:
As suggested have attached couple of pictures of the engine.
dax021:
Good on you for a speedy response. The learned members will soon comment. In the meantime, try get a few pics of the serial plate as this will help determine model and year
jddevel:
It's missing!!!!! Numbers embossed on sump are 203-30011.Hoping this might help
