Lister Engines > Lister Market Place (things for Sale)
18/1 with generator for sale
Powdermonkey:
https://www.facebook.com/marketplace/item/418566237418064/
Folks- I'm just passing this along. The guy's about 3 hours south of Tallahassee, but I'm already engine-rich and money-poor. Hopefully, I can help somebody.
broncodriver99:
Thanks for the heads up. Is that the going rate these days? Just curious.
ajaffa1:
Hi Guys, I had a look at that video. That engine will only produce around 8 HP at 800 RPM, you might get a little bit more at 850 RPM as per the advert. It will not drive an ST10 to produce 10KVA. That unit will max out at less than 5KVA.
I also have concerns about the cylinder head configuration, this is not a standard Lister CS clone. The top water coolant outlet appears to be on the fuel tank side rather than directly above the return pipe as is usual.
Powdermonkey:
Bob- That's an 18/1. Not a 10/1, or a 12/1.
Ken J
38ac:
If anyone here buys that I have all the wear parts in stock, none of which Interchange with other size engines
