Author Topic: 1925 Lister 2T and Generator  (Read 34702 times)
Bent Trigger
  • My Cat Says Arear!!
  • I can't lay off the Husqvarna!
Re: 1925 Lister 2T and Generator
« Reply #90 on: September 03, 2024, 10:17:41 PM »
So I sent the valve guides that I got from SEP to another Lister Engine Forum Member Keith71 and he said they were a very close match!! Guide to Well almost perfect and Just a little tightness on the spring to seat diameter!! I call that a Win.
I hope they work Well for Keith and he has no trouble, except finding the last one!!! I want to Thank:
Steven Perk at
Stationary Engine Parts
In England
For the Generous DONATION to the Lister Cause!!
And I am Glad to find another very close part that may Fit other Machines!!
And THANK YOU LISTER FORUM For allowing USE TO USE YOUR House to Trade Info and Banter Here!!
Back to your regularly scheduled Lister 2T rebuild!!
Chris in New Jersey
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #91 on: September 04, 2024, 01:44:30 AM »
Is he putting them in a CS or..?
Bent Trigger
« Reply #92 on: September 04, 2024, 11:27:56 AM »
I do not know.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
keith71
« Reply #93 on: September 04, 2024, 06:06:26 PM »
Just wanted to say thank you to chris for sending me the valve guides.. They are about as close as you can get to a replacement C/S guide other than getting the correct one.. My cs 12/2 had less than 8 hours runtime when I purchased it and tore it down.. The valve to guide clearence was extremely sloppy..
I know that stationary engine parts probably gets their guides from India as well, but it is from a good supplier.. The valve to guide clearance on these heads will measure perfectly .. A bit snug, but nothing one quick pass from a hone or reamer would fix.. The way they should be made and allow a builder to custom set his clearance. I am not sure of the valve to guide clearance to run. But as it stands now they can be set to any clearance we chose.  Every other measurement is the same. The biggest difference is where the inner valve spring sits on top of the valve guide.. That top flange is about .030 thicker than the originals. Which may give it a bit more installed seat pressure.. I do not know yet what the stock installed valve seat pressure or height is., as I doubt there is a spec. And Im pretty sure not many have checked what it is. But it can be measured with a springchecking tool..
I am thankful for these guides and will get one more from SEP..
I am also thankful for stationary engine parts and the real quality of these guides. And I also have purchased from them before as well, and thought there stuff was just better then the generic poorly made parts I have purchased from DEV on ebay.. Stationary engine parts  are super helpful people..
Thanks again Chris and Stationary engine parts.
« Last Edit: September 04, 2024, 06:35:57 PM by keith71 »
12/2 Field Marshall
Jiangdong R170.
keith71
« Reply #94 on: September 04, 2024, 06:26:59 PM »
Chris, one more question . Are these guides genuine Lister? Thanks.
12/2 Field Marshall
Jiangdong R170.
Bent Trigger
« Reply #95 on: September 04, 2024, 10:23:58 PM »
I don't know Keith I guess I could email Steve and see what he says super nice guy though so I'm sure he'll get me an answer I'm glad that they're measuring up. They will last three had on the website so I'm assuming you're going to be waiting for a new batch I did not measure them but if you send me the measurements I can probably make you one from the same cast iron I'm making mine out of once I get this machine up and running I'm probably going to make another set out of silicon bronze I don't know why I didn't do that in the first place also Keith if you're interested in a lathe I happen to have an Old South bend that's not a quick change gearbox that I might part with let me know if you want pictures
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #96 on: September 05, 2024, 11:35:09 AM »
I sent Steve at Stationary Engine Parts an email with the question Keith. I also added a couple screen shots of our conversations here. I will advise if he responds. Have a Great Day! Chris
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #97 on: September 05, 2024, 01:37:58 PM »
Put new balls in the oil pump and laid it out for Rob at OTE to confirm. He said Good to Go! So i reassemble and test , nice working perfect even the Telltail pops!!
https://photos.app.goo.gl/Znm6mccJCWstBxgP6
Somehow my phone switch to slow mo which is cool with both my hands on the pump kind of weird. Enjoy!!
« Last Edit: September 05, 2024, 01:39:43 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #98 on: September 06, 2024, 06:08:47 PM »
From Steve at SEP
Hi Chris,
Thank you for letting me know, I am delighted to hear that they have been put to good use.
I am pretty sure the L type ones we make in our own workshop from Meehanite bar.
Regards,
Steve Perks
Stationary Engine Parts Ltd.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
keith71
« Reply #99 on: September 06, 2024, 08:23:58 PM »
The oil pump video was good.. Hard to tell exactly but it looks like the same type of pump as My cs 12/2 clone.. I bought the replacement spring kit from sep a while back.. I got to get going on my engine and stop slacking off.. Very neat and detailed work you do there chris..
Thanks for passing along what steven at sep said about the guides.. A quick search on meehanite tells me it is a very good type of iron.. Being a quality company, no surprise there that they would use it..  Thank's Keith.
« Last Edit: September 06, 2024, 08:33:06 PM by keith71 »
12/2 Field Marshall
Jiangdong R170.
Bent Trigger
« Reply #100 on: September 06, 2024, 09:01:16 PM »
No worries Keith I had to buy a 20 of those balls for the pump so if you need a few let me know they're half inch. Here's a pic of that pump disassembled.
https://photos.app.goo.gl/AWeb8UNPiR2jdY5n8
« Last Edit: September 06, 2024, 09:06:03 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #101 on: September 07, 2024, 08:38:49 PM »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #102 on: September 08, 2024, 03:52:16 PM »
Top End assembled just some nuts to install then fill the crank case with oil and prime the engine with a dowel on the pump rod !! :)
https://photos.app.goo.gl/NCj8d2RgWe3RSbm49
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #103 on: September 09, 2024, 11:31:41 AM »
I think I mis-measured my ring gaps, so it has to come apart and be checked.
I'm pretty sure I set these at .003 and they should be .0165.
To be continued.
« Last Edit: September 09, 2024, 05:01:06 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
keith71
« Reply #104 on: September 09, 2024, 05:34:53 PM »
Good catch lol.. .003 sounds a bit snug ;D  .003-.004 per inch of bore maybe ?
« Last Edit: September 09, 2024, 05:44:15 PM by keith71 »
12/2 Field Marshall
Jiangdong R170.
