Author Topic: 1925 Lister 2T and Generator  (Read 25572 times)
Re: 1925 Lister 2T and Generator
« Reply #75 on: July 29, 2024, 09:15:25 PM »
I don't see any plain brass but they do have nickel plated brass and stainless.
Close nipples in nickel plated brass, one has a metric hex the other is standard:
https://www.mcmaster.com/9491N12/
https://www.mcmaster.com/9151K377/
Close nipples in stainless, one is 304ss and the other 316ss: https://www.mcmaster.com/9027N129/
https://www.mcmaster.com/9027N139/
Here are dowty washers if you need them. https://www.mcmaster.com/products/dowty-washers/
Looks like they only have the plugs in Stainless:
https://www.mcmaster.com/3600N44/
https://www.mcmaster.com/3600N25/
« Reply #76 on: July 29, 2024, 09:20:44 PM »
It looks like a lot of hydraulic fittings are bspp as well so that may be another place to dig around.
Bent Trigger
  • My Cat Says Arear!!
  • I can't lay off the Husqvarna!
« Reply #77 on: July 29, 2024, 10:53:46 PM »
Thanks for the help there BD. I'm really looking for original looking Nips and Plugs. I will probably make my own for the price they are getting. I have only started on the top end. I cleaned a bunch of rusty bolts and such today and got the internal rotating sections in. Crank, am and Timing Idler. All set, then cam followers and guides. So I am making progress.
https://photos.app.goo.gl/UQhGwUeCArxEEX9U9
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #78 on: July 30, 2024, 03:57:33 PM »
Does anyone know how the exhaust valve cut out works and what the linkages look like to make it work?
I assume this is for auto start from the gen end and it is solenoid activate? Because I have 2 solenoids. One for the choke? And one big one for , I'm thinking this auto exhaust valve interuptor ?
Any pics or advice is welcomed.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #79 on: July 30, 2024, 10:47:56 PM »
https://photos.app.goo.gl/MiHsgX72oGGvBSiW8
Pull the big coil apart for cleaning did not break anything thank God this thing has got a really heavy drop pin but it worked hopefully it will when I'm done r
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #80 on: August 04, 2024, 12:17:57 AM »
More small assembling and a clean for the Magneto. All Timed with a New Chain for it too. I'm not sure which cylinder is #1 or #2, so I timed it to the gen side cylinder. We will see if it will run that way. Found a crack in the oil pickup when I went to install. Not in 2 pcs yet but I better be looking for one. Oil pump on and the pickup tube cleaned and installed. Waiting for the valves from Rob at OTE, then off to the Machine shop for New Valve Guides to match. I could buy new guides but because of the way they repaired the one exhaust valve I am afraid the guide hole is enlarged. So a new one will have be made. Then I can install the rest!! Pistons, Rods, Heads/Cylinders. Moving along!!
https://photos.app.goo.gl/VPVuVFo7uiEYyFeGA
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #81 on: August 23, 2024, 06:22:39 PM »
I got the valve guides from Stationary Engine Parts in England. Not what I was hoping for! The listing pic looks exactly like my guide, the new guide does not.  I guess they change over the years but this is wrong on EVERY measurement except the bore which is looser than I thought! I will have to complain about this and do my best to beat them into submission! I assume they will refund but I WANT MY GUIDES!!. Prolly going to have to make my Own!! All will be calipered in the future to get the exact numbers. Very busy right now!! I hope the springs are not as far off!!
https://photos.app.goo.gl/aTghqWrDp9UgeuNx5
« Last Edit: August 23, 2024, 06:24:25 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #82 on: August 24, 2024, 01:23:49 AM »
https://photos.app.goo.gl/LsZeDWD2umeUdtKfA
Here's the caliper measurements of the Original and New bought guides! Man am  I disappointed!!
« Last Edit: August 24, 2024, 01:38:01 AM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #83 on: August 24, 2024, 07:58:49 AM »
Looks like they may have sent you CS valve guides by mistake.
https://www.stationaryengineparts.com/Lister-CS-VA-and-JP-Valve-Guide-Inlet.html
I have dealt with SEP many times and they have always been great. On the couple of occasions there was an issue they quickly made everything right.
Bent Trigger
« Reply #84 on: August 24, 2024, 01:54:41 PM »
Looks like you may be right there Russell. WOW what a price difference! WTH!! We will see what happens next week. Seems this stuff always happens on a Friday! Oi!!
« Last Edit: August 24, 2024, 02:12:47 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #85 on: August 26, 2024, 12:50:36 AM »
Sanding a fly wheel and blasting one of the heads and getting the one original piston ready
https://photos.app.goo.gl/qEo4HzFbWRPV5Jf46
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #86 on: August 27, 2024, 12:44:35 PM »
No response from SEP.
Sent another email. ???
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #87 on: August 28, 2024, 02:10:23 PM »
Valve Guide Problem Solved!
If anyone needs these guides let me know.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
keith71
« Reply #88 on: August 29, 2024, 12:12:58 AM »
I have ordered a few times from them.. They are a stand up group of folks.. Glad to hear the build is getting there.. sent you a pm on the guides.
12/2 Field Marshall
Jiangdong R170.
Bent Trigger
« Reply #89 on: September 02, 2024, 10:08:06 PM »
Got a few guides done. Also a light hone on a cylinder and a measurement of the upper cylinder. Then adjust a set of 4 rings all pushed in to the same lower section depth. And a Lapping of the New Valves in their New Guides! :D One more guide to make as I'm not a very good machinist and had to Scrap 2 Pcs!! :P Now for Studs and Tape then Paint!! Getting closer!!
https://photos.app.goo.gl/EVM2wKhATKuUs57JA
« Last Edit: September 02, 2024, 10:13:52 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
