Author Topic: 1925 Lister 2T and Generator  (Read 14345 times)
Re: 1925 Lister 2T and Generator
« Reply #60 on: June 16, 2024, 11:34:04 AM »
Hi Bent Trigger, yes there is a lot of internal dirt shown in your photos. There is a product called flushing oil which will remove most of it without a complete disassembly. Get the unit running and then drain out the oil. Replace the oil with flushing oil, run the engine up to normal working temperature (probably around a half hour run but follow the instructions on the tin), drain out the flushing oil and replace with regular oil. Do not throw out the flushing oil, let it settle and it can be reused.
Bent Trigger
  • My Cat Says Arear!!
  • I can't lay off the Husqvarna!
« Reply #61 on: July 07, 2024, 12:54:02 PM »
Took it completely down for a good cleaning and inspection and a fresh epoxy coat. Hope to start reassembly soon. Anyone know where to get gaskets or do u have to maked my own?
https://photos.app.goo.gl/q6CsZkDmR9h4va5ZA
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #62 on: July 07, 2024, 11:29:04 PM »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #63 on: July 13, 2024, 10:40:52 PM »
https://photos.app.goo.gl/xMc2tV2Um4BFS6j4A
Here's the first paint sample code. The running list is exact to this sprayout. The upper number is very close.
Also cleaning a lot of nuts and bolts and got a coat of green on the block and some other stuff. Another coat tomorrow and I can move on to the cylinders and some small things for the next step. And start the assembly. So far only found 2 broken spring washers.
« Last Edit: July 13, 2024, 10:47:36 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #64 on: July 13, 2024, 11:07:44 PM »
Also
The SmokStak is down.
Don't remember that ever happened before.
Hope all is well with Harry and Family.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #65 on: July 15, 2024, 04:14:26 AM »
SmokStak is Back!
There is a bolt between the cylinders over the cam that is about 2.5" long. It pins the center cam guide. When the bolt is removed the center cam guide(MY Word For IT) being larger than the oil pump eccentric will allow easy removal of the cam towards the drive/governor weight end!
https://www.smokstak.com/forum/threads/lister-2t.229233/post-2004082
Just so You Know !!
When I add a Link to a Post
It is google photos
When you click on a Pic you can Use your mouse wheel to Enlarge/Zoom into the Pic!!
My Phone is a Google Pixel and takes Great Pics!
It may take a couple of seconds for your computer to completely load/refresh the Pic as you ZOOM!
And you can really see how shaky my Pics are!!ENJOY!!
Also Can I use Crocus Cloth to Polish the Journals?
And should clean up the bearings that have roll over into the oil slots?
« Last Edit: July 15, 2024, 04:17:24 AM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #66 on: July 21, 2024, 11:07:22 PM »
https://photos.app.goo.gl/W7tEBKygsRF63wjYA
More work on the lister clean cam and crank
Trieing to make gaskets
Clean the sump again
Anyone know what the silver lining is in the sump
Don't want to use glyptol
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
keith71
« Reply #67 on: July 22, 2024, 08:18:41 PM »
I dont know what the silver lister paint was.. Get the inside clean and oil free and Use white 2 part epoxy primer/sealer, and never think about it again..
« Last Edit: July 22, 2024, 08:21:08 PM by keith71 »
12/2 Field Marshall
Jiangdong R170.
Bent Trigger
« Reply #68 on: July 28, 2024, 12:14:28 AM »
So I take your advice Keith finish cleaning looks like I missed a couple of spots but I think we'll be okay and my first coat of white inside of it. Tomorrow one more coat and then I got start assembly as I finally learned how to make gaskets they're not great but cheap and I have them.pics
https://photos.app.goo.gl/ZeRkyvrMMk9LcRmC8
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #69 on: July 28, 2024, 06:52:02 PM »
So I Have been Painting the inside and while it's drying I decided to start cleaning up the cylinders. I took my DA sander to the machined faces and got those pretty nice. Then started to clean the intake and exhaust ports. NicE! There was one valve guide that was not so nice!! The valve must have been rotted thru so they cut the Guide and welded it to the valve stem to cover the rot. So there was no valve guide, It was Now a valve Cycling in/on the L Head Guide Hole!!! WTF!!! Any Hoo, Gonna have to have a new Guide made and talk to Rob at OTE, (my latest purchase just landed in the USA). So because I am ANAL, I'll buy all 4 valves and have all 4 guides replaced and See if Rob can come up with a New Set of Springs. I cant Find the BSPP Plugs either. They are everywhere in the World BUT not the USA!! And I need 4 BSPP close nips for the water System. I Found a Water pump (Thanks Sunnybrook) that I think I can Make work With the Titan Radiator. Its Gonna be pretty cool if I can Pull It Off!! Also the Wick style oiler for the Cam cover need to be replace Unless someone can show me how to rebuild it!
https://photos.app.goo.gl/2zRWtFgfaiYUFDeZ7
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #70 on: July 29, 2024, 02:53:55 AM »
Give Mcmaster-Carr a try for the BSP and BSPP stuff. It may take some digging but they do have some stuff.
« Reply #71 on: July 29, 2024, 02:57:46 AM »
I just looked and they have a pretty good selection of BSPP and BSPT fittings.
« Last Edit: July 29, 2024, 03:03:52 AM by broncodriver99 »
Bent Trigger
« Reply #72 on: July 29, 2024, 03:43:15 AM »
I tried them they don't have the straight pipes or what they call parallel
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #73 on: July 29, 2024, 12:45:24 PM »
What size?
Bent Trigger
« Reply #74 on: July 29, 2024, 02:38:21 PM »
1" BSPP shoulder nips 4 pcs
1"BSPP Flanged Plug
Both in brass
I think I orders the plugs from Rob, but I'm not sure if they were BSP or BSPP.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
