Author Topic: 1925 Lister 2T and Generator  (Read 38975 times)
keith71
Re: 1925 Lister 2T and Generator
« Reply #135 on: September 30, 2024, 08:40:53 PM »
There is not much info out there on this engine from my searching so far..  I am interested in finding out the rpm and hp. Strange how they did not stamp that on your engine plate..
At first I thought it is direct drive, so to get 50HZ in england it would turn at 1500 rpm provided it was a 4 pole gen head.
However this is not an AC type head. As far as I know and from what I have read on this thread.
It is DC so the engine may turn 600 rpm but the generator would put out 120v DC..  So speeding it up will increase the volt output I imagine.
Inquiring minds want more info on this setup..  It is an interesting setup.. Please let us know when you find more info on your new toy. Thanks.
12/2 Field Marshall
Jiangdong R170.
keith71
« Reply #136 on: September 30, 2024, 08:44:50 PM »
Maybe a PM to ajaffa1 (Bob) on this forum would yield some more info..  He is a pretty good generator guru from what I have read from him on this forum. Just a thought.
12/2 Field Marshall
Jiangdong R170.
Bent Trigger
  • My Cat Says Arear!!
  • I can't lay off the Husqvarna!
« Reply #137 on: October 01, 2024, 12:47:42 AM »
I will be doing more testing as time become available. I have a Day Job so!!!
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #138 on: October 04, 2024, 02:10:08 PM »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #139 on: October 04, 2024, 02:14:53 PM »
https://photos.app.goo.gl/38v5GYHfwgiPBmCX7
The gen went 220vdc with the governor not set up
Pulled the governor down and got it at 125vdc
Running at around 600rpm for that
More testing this weekend.
« Last Edit: October 04, 2024, 05:51:00 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #140 on: October 06, 2024, 08:59:01 PM »
Got it outside ran it a few times hooked up the water and forgot to put a drain in the water tank we got control voltage around 125 whenever I want it when the governor linkage isn't falling apart so that's about it for this summer I don't think I'm going to bring it to Cool spring it's just too much work right now and I'm beat. Over the winter I'll pull the Gen end and redo it completely and then next year I'll bring it to the June show. I'm still going to come out for this year/ next week. But I'm not bringing anything I'm just going to come and check it out. Be good for me to figure out what the hell's going on anyways without the personal distraction. Enjoy!
https://photos.app.goo.gl/FuJH7ZGezAWfjuXF7
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #141 on: October 06, 2024, 11:24:03 PM »
I really want to Finish this Project Before Displaying It. A lot of Nickel Plating. A correct size Tank. Possibly The Radiator and Water Pump!! No water leaking from the cover studs(I didn't seal them:music) and the Gen end and a slate panel for the electrical Works. A fuel Tank and some other things.
But I am happy with my Progress and am looking forward to Displaying It when Finished!
Of Course the questions will continue and I will post it all on this thread.
Thanks to everyone for helping me get this far!! Pretty Cool!!
125VDC @ 480RPM!!
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #142 on: October 09, 2024, 12:25:42 AM »
Ok Guys, This Project is Done for the Year! :)
Thanks for the help and advice!
I will finish the  Gen end that is producing voltage  in February!
I have a TON O Projects to finish so I'll see ya later. Chris
https://photos.app.goo.gl/kXHa6Co1nYPaJUz79
https://photos.app.goo.gl/cpPEsRPRyXNGGYdN8
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #143 on: October 09, 2024, 05:22:47 AM »
Nicely Done!
Bent Trigger
« Reply #144 on: October 21, 2024, 12:08:31 AM »
https://photos.app.goo.gl/u53yKBDniduefGGB8
Videos with out the fat guy blocking the view!!
I've been collecting parts for the gen end and the control of the output. Still not sure what will be the outcome!
Proof that no Project is complete!! Enjoy!!
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
old seagull man
« Reply #145 on: October 22, 2024, 04:19:18 AM »
Wonderfull to see the old girl running.
Bent Trigger
« Reply #146 on: March 06, 2025, 02:03:20 AM »
So February is Gone and I haven't brought the machine Back in from the Winter Yet.
Lots of goings on Here in New Jersey.
Hope to get to it soon.
Hope you all had a pleasant Winter!!
Spring is around the corner!!
Chris
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #147 on: April 13, 2025, 02:03:49 AM »
Ok, I'm back for a bit. Put the Machine back in the shop. Leaking oil from the the cracked lower oil pickup. Other than that and some dust and rust, all good.
Pulled a ton o parts to take to the polisher to get them prepped for new Nickel plate. And am trying my hand at cleaning the nuts and bolts with a tumbler to see if I can get them spiffy without taking too much metal away.
I haven't decided on what to do with them, Paint, Nickel, Bluing or some other such.
Then the BIG Kahuna!! The 1000# Generator. Should be pretty straight forward to Disassemble, Clean, Paint and Reassemble.
I've been Kicking Ass this Year.
Last Dec 31st My company Folded. They warned me Nov 15th and gave me 4 months Severance. I was 2.5 months shy of 30 Years!
So being 63 and not looking forward to Job interviews, I started My Own Company using my old company customers. What I do Is pretty specialized and you you can't just sell experience! The Old Owners are in there 80s and just want to sell everything including the building and not look back. So I have 3-4 years to make some real coin and help my other office guy learn the tricks. We have been working together for 25 yrs and he is smart and for the last almost 2 years has been learning the field.
So here I am learning Quickbooks and he is learning how to make a burner not hurt anyone.
The building is supposed to be here until the end of the year so I have to move fast and work 6/12hr days at the same time.
So there's the POOP!
And here's some pics.
https://photos.app.goo.gl/gG7PmhEuE6Xu8vEw6
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
keith71
« Reply #148 on: April 18, 2025, 11:22:16 AM »
Those parts are going to look great polished and plated..
Looking forward to the generator inspection and cleanup.
Pretty slick on the new (old) job startup. Makes it alot easier to work with guys you already know and trust. Hope you have continued sucess on that new project in life..
12/2 Field Marshall
Jiangdong R170.
Bent Trigger
« Reply #149 on: April 27, 2025, 11:18:00 PM »
https://photos.app.goo.gl/NZFVpV3jEEykPsAK8
Generator end Disassemble.
Interesting to see the pole shoes are cast into the generator end very very robust.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
