Author Topic: 1925 Lister 2T and Generator  (Read 103979 times)
Bent Trigger
  • My Cat Says Arear!!
  • I can't lay off the Husqvarna!
« on: January 03, 2024, 11:58:03 PM »
Hi, I have a Lister 2T with a Generator. I saw a listing on the SmokStak last year and it was still up after a few weeks so I called and made an appt to look at it. When I walked in I was floored by the size! I was looking for a little diesel engine. So after making a deal and waiting thru the winter and multiple other issues I was finally able to get a trailer and a good friend to move it. It was up in Ticonderoga and about 4 hours each way and I figured 2hrs to move it to the trailer. Got it done on the first weekend of June 2023. I started to take a bunch of pics and get it located in the rear yard at the shop. I started to take it apart as it would not roll over. When removing the 2nd cylinder it toppled and broke a piston. What a fool working by hand with a 60lb cylinder when I have all manner of lifting equipment. Oh Well!! So the search was on for a piston. With the cylinders and pistons off the machine rolled over. I called the Cattail Foundry out in Pennsylvania and they said the could cast me new pistons. I wanted two so when machined they would be as close to identical as possible. I also emailed Rob at Old Timer Engines in Australia because he had 5.5" rings in stock. I bought a set of 8 anticipating new pistons right around the corner. Well 6 months later I am getting antsy and asking the guys on the Stak about Diesel pistons and how to get some to work. Justin/Famous Fitter asked if I had asked Rob if he had any pistons I was like, I'll email him right meow :laugh:!! Well it's Christmas time and he was on Holiday so the wait. He emailed me on the 2nd of this new yr and said he had a couple of newer style flat top pistons and would dig them out for pics. I was like Newer Style? I need some from 1925!!So I went to the shop and took some pics of the good original piston, ring placement, wrist pin size and others and sent Rob a link with them. The Next am I got this pic! I was sooooooo Happy!! We made a deal and they are on the way to New Jersey now!! More to follow! Chris
« Last Edit: January 04, 2024, 12:17:20 AM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
Re: 1925 Lister 2T and Generator
« Reply #1 on: January 04, 2024, 12:12:16 AM »
In case you were wondering this story was also published in the Stationary Engine Magazine in I think August and will be added to as things develop. Here's a set of links for most of the pics I have. Enjoy Chris
https://photos.app.goo.gl/9TNaBXMz6qtf56iC6
https://photos.app.goo.gl/2DyHb3gvt4Qnz4p6A
https://photos.app.goo.gl/XXAuxCodLqQkEvUJ6
https://photos.app.goo.gl/qtcMTzzLWf8Sk4dm6
https://photos.app.goo.gl/YiDuvTgbZW8F44W16
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #2 on: January 04, 2024, 02:51:42 AM »
What a Beast! Looks like a DC genset? Looking forward to the updates.
Bent Trigger
« Reply #3 on: January 04, 2024, 11:48:42 AM »
I think so, it has 4 big coils and 2 smaller coils. I cleaned all the brushes up and they move freely in their holders and she spins so just need to figure the voltage to get her to spin with the commutator. All suggestions are welcome.
« Last Edit: January 04, 2024, 11:50:45 AM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #4 on: January 08, 2024, 03:33:53 AM »
I'm looking for parts for this ML CK2 magnetos lead out and plug connector. Any leads are welcome.
https://photos.app.goo.gl/gWDvqfyQAZq1jkfw8
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #5 on: January 10, 2024, 11:14:24 PM »
Pistons have arrived to their new home. They are exact replacements with the same Part number inside!! Time to start cleaning and trying to get it together.
Special Thanks to Rob at Old Timer Engines!!
rob@oldtimerengines.com.au
« Last Edit: January 10, 2024, 11:18:03 PM by Bent Trigger »
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #6 on: January 16, 2024, 11:38:29 PM »
Starting to clean the old girl, not too much schmegma in the sump! Took one side of the cam followers out and cleaned them a bit. All the nickel plated stuff will be re plated and the entire unit re painted in the Mid Brunswick Green.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #7 on: January 17, 2024, 01:26:49 PM »
Nice gen set! I have a TL that came from up that way. There is a Lister twin set like yours at the museum in Coolspring Pa.
« Last Edit: January 17, 2024, 05:23:47 PM by 38ac »
Bent Trigger
« Reply #8 on: January 17, 2024, 11:06:41 PM »
I wondered how many 2 cylinder L head listers made it to the USA.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #9 on: January 18, 2024, 12:03:48 AM »
Ive known about half dozen of them, guessing there are quite a few more around that I don't know about.
Bent Trigger
« Reply #10 on: January 18, 2024, 01:02:08 AM »
I know Generator Gus Has one in Mountaintop PA and tommy the Judge has one in I think Missouri. Heres Gus and His sweet machine.
https://drive.google.com/file/d/1RX3qr8F-FrfqfJ99zcvSQ9WjqrtH9xXx/view?usp=drive_web
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #11 on: February 03, 2024, 12:21:34 AM »
Sent the base off for blasting.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #12 on: February 03, 2024, 12:24:34 AM »
Testing my new phone pics dont add to this
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
« Reply #13 on: February 08, 2024, 11:48:16 PM »
Looking to get a spray out of Mid Brunswick Green spec 381C shade 226 sent to me asap to be added to the USA Data Base!!!
All the engine sites will not ship paint to the USA!!
Any Help Is Wanted!!
If you have or you know where someone with a Spray Out is Please let me know!! I only want a Spray Out because I can't trust the paint on my machine and would not want to do it twice!! Thanks Chris 201-370-5471
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
« Reply #14 on: February 09, 2024, 06:45:12 AM »
That's a tough ask. Butch (38ac) IIRC got close. Apparently mid brunswick green is just unattainable in the US for whatever reason. I did find that Mack Green is a pretty close substitute and available off the shelf just about anywhere. It is a little more "green" than mid brunswick but acceptable in my opinion. Then again I have 4 various original Listers and none of them are the exact same color so there was some varience.
