Author Topic: 1925 Lister 2T  (Read 6425 times)
Bent Trigger
  • My Cat Says Arear!!
  • I can't lay off the Husqvarna!
1925 Lister 2T
« on: December 21, 2023, 12:18:04 AM »
First post here. I'm looking for a 5.5" Piston for this old gen set engine. Any leads would be welcome. Thanks Chris
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
Re: 1925 Lister 2T
« Reply #1 on: December 22, 2023, 02:29:00 AM »
Forgot the pics.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
Re: 1925 Lister 2T
« Reply #2 on: January 03, 2024, 12:30:19 AM »
Pistons Found!!!
Rob from Old Time Engines in Australia had a couple so, They are on their way to New Jersey! ;D!!
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Re: 1925 Lister 2T
« Reply #3 on: January 03, 2024, 02:51:49 AM »
Pistons Found!!!
Glad you found them. Interesting Lister. Looks like the Lister CS has a lot in common with it.
How was the shipping from down under? I am down in Virginia and Rob has a couple of parts I am interested in.
Bent Trigger
Re: 1925 Lister 2T
« Reply #4 on: January 03, 2024, 02:16:45 PM »
Hi Bronco, These were a lot because they weigh 11kg
But the exchange rate is not bad and Rob is a steller seller!!
Good luck and link you Lister thread so I can check it out.
I broke a piston on disassembly and am paying the piper so to speak.
I have never ran it so It will be interesting to see if I can get it to auto start with gen end excitement. I will start a new thread once I get the pistons and regale you all with my screwing around!!
Chris From New Jersey!!
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Re: 1925 Lister 2T
« Reply #5 on: January 03, 2024, 02:42:25 PM »
Yes, I. ought some parts from him shipped to the states. He is A1 plus in every way.
Re: 1925 Lister 2T
« Reply #6 on: January 04, 2024, 02:56:08 AM »
Here is a link to my build thread. Sadly I haven't had much time the last couple of years to get back to it. Hoping to remedy that soon. Welcome aboard and looking forward to your other thread.
https://listerengine.com/smf/index.php?topic=7612.msg86188#msg86188
