Author Topic: 1925 Lister 2T  (Read 25437 times)
Bent Trigger
  • My Cat Says Arear!!
  • I can't lay off the Husqvarna!
1925 Lister 2T
« on: December 21, 2023, 12:18:04 AM »
First post here. I'm looking for a 5.5" Piston for this old gen set engine. Any leads would be welcome. Thanks Chris
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
Re: 1925 Lister 2T
« Reply #1 on: December 22, 2023, 02:29:00 AM »
Forgot the pics.
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Bent Trigger
Re: 1925 Lister 2T
« Reply #2 on: January 03, 2024, 12:30:19 AM »
Pistons Found!!!
Rob from Old Time Engines in Australia had a couple so, They are on their way to New Jersey! ;D!!
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Re: 1925 Lister 2T
« Reply #3 on: January 03, 2024, 02:51:49 AM »
Pistons Found!!!
Glad you found them. Interesting Lister. Looks like the Lister CS has a lot in common with it.
How was the shipping from down under? I am down in Virginia and Rob has a couple of parts I am interested in.
Bent Trigger
Re: 1925 Lister 2T
« Reply #4 on: January 03, 2024, 02:16:45 PM »
Hi Bronco, These were a lot because they weigh 11kg
But the exchange rate is not bad and Rob is a steller seller!!
Good luck and link you Lister thread so I can check it out.
I broke a piston on disassembly and am paying the piper so to speak.
I have never ran it so It will be interesting to see if I can get it to auto start with gen end excitement. I will start a new thread once I get the pistons and regale you all with my screwing around!!
Chris From New Jersey!!
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Re: 1925 Lister 2T
« Reply #5 on: January 03, 2024, 02:42:25 PM »
Yes, I. ought some parts from him shipped to the states. He is A1 plus in every way.
Re: 1925 Lister 2T
« Reply #6 on: January 04, 2024, 02:56:08 AM »
Here is a link to my build thread. Sadly I haven't had much time the last couple of years to get back to it. Hoping to remedy that soon. Welcome aboard and looking forward to your other thread.
https://listerengine.com/smf/index.php?topic=7612.msg86188#msg86188
Bent Trigger
Re: 1925 Lister 2T
« Reply #7 on: August 15, 2025, 03:36:39 PM »
Hi guys I am now looking for an oil drainer elbow for the bottom of mine mine is cracked and I tried to braise it but it's not taking well.
Figured I'd figured I'd reach out and see if anybody may be had one that they can part with I pay cash I pay fast.
Thanks Chris
201 370 5471
https://photos.app.goo.gl/uedNyyLX4D7ZqTE59
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Re: 1925 Lister 2T
« Reply #8 on: August 18, 2025, 11:50:49 AM »
Interesting because I have a twin L myself, same spec and that part is not the same. Wondering how the oil is drained? You are in luck,, I think? Pictured are the same elbow from a very early 10/2 I own and also a 16/2 Listeroid. I do believe that either would work perfectly in place of your original. I didn't check this out to the inth degree because I didn't want to remove them to check. The CS engines are descendents of the model L and share a sone parts. first pic in my TL notice oil drain plugs, next is my 10/2, last is the Listeroid twin. Any of the CS/Listeroid parts would be easier to find than twin L parts.
Bent Trigger
Re: 1925 Lister 2T
« Reply #9 on: August 18, 2025, 12:32:12 PM »
Thanks for the pics and info AC.
Mine has a check ball in it to keep the oil in the pipe.
And it looks original with no way to drain the oil.
I have feelers out around the world so we will see if one pops up.
I am going to clean this one up again and have my certified welder try to weld it.
Otherwise I will take a cooling plug and drill and tap npt then cut the threads off this and tap to npt. and put a cl nip-tee-cl nip to add a drain and retain the check ball feature.
THEN I can add an oil filter. What a PIA!!
Thanks Again for the info!!
Chris
Multiple Husqvarna
Multiple Generators
Multiple Projects
       Manchu
Keep Up The Fire!!
Re: 1925 Lister 2T
« Reply #10 on: August 18, 2025, 02:11:57 PM »
I do not have a TL parts book but I'd bet the TL and early CS twins share the same part number. The drain plugs were such a small modification that Lister appearantly didn't see fit to change the spec which is also unusual. The CS engines also have a check ball retained by the adapter fitting. The TL oiling system, pump, lines and function is identical to the CS twin
« Last Edit: August 18, 2025, 02:14:38 PM by 38ac »
Re: 1925 Lister 2T
« Reply #11 on: August 18, 2025, 02:12:47 PM »
somehow duplicated my post here
« Last Edit: August 18, 2025, 02:14:18 PM by 38ac »
