Author Topic: CS 12/2 dating and spec number  (Read 7298 times)
RJ
« on: December 03, 2023, 12:43:47 PM »
Can't seem to locate any of Peter's Old pages on the web anymore, but looking to date my lister.
# S85771    Spec 10/2/30
12hp       RPM 650
Thank you,
RJ
Re: CS 12/2 dating and spec number
« Reply #1 on: December 04, 2023, 11:24:34 PM »
According to my sheets its a 1951, the last year for that numbering system.
RJ
« Reply #2 on: December 06, 2023, 07:39:25 PM »
Thank you, very much appreciated, sir. Any thoughts on Spec number? It has solid spoked flywheels, no pulley groves so assume it was generator spec'd.
RJ
« Reply #3 on: December 06, 2023, 10:42:43 PM »
Spec numbers were assigned to every change in the CS line, be it an improvement or a special order. Thus they could ship correct repair parts. They are often confused for dates but they are not. To my knowledge there is no comprehensive list of spec numbers and the changes. A few if them were known by David Edgington and listed in his book.
RJ
« Reply #4 on: December 09, 2023, 01:07:20 AM »
Right on, Thank you for the information. I got the old girl up and running. Cylinder two seems to have a stuck ring perhaps. It will run but smokes a bit when I release the change over valve. exhaust isn't as warm, as the other. Not sure if just running it will loosen it up or not.  ???
