Author Topic: New toys.... JP4 Hr3  (Read 5841 times)
Owenga
« on: October 14, 2023, 11:47:21 PM »
Hi..
I have purchased two Lister engines firstly a tidy running HR3 that has had a generator but it had been taken off and probably gone to scrap. I will put 3ph 12/15 Kw alternator on it and mount on a trailer as a power supply for on site engineering work..
The most interesting engine by far is a JP4 I just bought that has had its alternator removed as well. This engine has been shed stored and in very good condition and turns over freely. I’m not sure what I’ll do with it..... I’ve always wanted an old Launch with a Lister or Gardener so it might end up being a marine engine.. the tag has  “spec 38 4 34 ‘.. I’m thinking it’s 1938 ?
Powdermonkey
Re: New toys.... JP4 Hr3
« Reply #1 on: November 28, 2023, 11:22:52 AM »
Owen- Are you located in the states, or UK?
« Reply #2 on: November 29, 2023, 10:11:14 AM »
Ooh, nice...
Can you get the serial number? We can date it from that...
Owenga
« Reply #3 on: December 01, 2023, 07:35:49 PM »
Hi powdermonkey.
I’m in New Zealand...
The serial number on my JP4 is  35677 there is another tag
Plant No 8969LB.      Engine No 6084766.  ( it’s hard to read )..
Thanks you guys.  Daryl....
« Reply #4 on: December 02, 2023, 01:56:53 AM »
Hmm, well, if I'm reading the table right....
The engine is a 1951, possibly one of the very last ones made that year.
The other tag (on a base?) would be the combination of engine/alternator - based on that tag, your engine is not the original engine for that base.... and the base was likely a 1950 (further assuming that the engine number is actually 6034766 rather than 6084766).
