Author Topic: TS2 cylinder head and top plate separation  (Read 3167 times)
Grange1
« on: September 09, 2023, 10:39:00 AM »
Hi All, new to the forum and not a mechanic so be gentle please  :). The exhaust port on the cylinder head is broken and I have found a replacement. However I can’t work out how to separate the cylinder head from the top plate. Is this possible to do as a home project? Any helpful advice will be appreciated thank you.
« Last Edit: September 09, 2023, 10:40:31 AM by Grange1 »
Grange1
Re: TS2 cylinder head and top plate separation
« Reply #1 on: September 09, 2023, 10:46:45 AM »
A couple more pics
« Reply #2 on: September 10, 2023, 12:43:11 PM »
Welcome to theForum. Can you sit your replacement part next to what you have and compare the difference to see if or how it seperates. Sorry I am not familiar with your problem but just throwing an idea out there.
Grange1
« Reply #3 on: September 11, 2023, 01:38:24 AM »
Thanks for replying Cobba. It looks like the two pieces are joined via the valve guides, and this seems to be a very tight fit. I was hoping someone could advise how to separate without having to go to a workshop to have them pressed out. Weary about causing damage by just hammering away.
« Reply #4 on: September 11, 2023, 12:47:58 PM »
yeah sounds odd. There are guys here who can give you a positive reply but sometimess it takes time. Sorry I  cant be of any help with this problem
Grange1
« Reply #5 on: September 12, 2023, 12:26:33 AM »
All good mate. Appreciate you showing an interest.  :)
Diesel Engineering
« Reply #6 on: September 12, 2023, 12:08:34 PM »
To separate the two parts of the head you will need to remove both valve guides. Not to difficult if you have access to a press.
Grange1
« Reply #7 on: September 12, 2023, 11:56:19 PM »
Thanks Diesel. I thought that might be the case, however was hoping for maybe an old timers method to avoid having to pay somebody. Looks like it’s off to a workshop. Thanks for your input mate, cheers.  :)
