Author Topic: What is this in the photo?  (Read 4193 times)
Altonx
« on: September 04, 2023, 09:00:17 PM »
What is this circled in the photo, AC2W engine?
I've seen alternators wired to this, is it for an ammeter?
Re: What is this in the photo?
« Reply #1 on: September 05, 2023, 12:37:24 PM »
To me it looks like an oil pressure switch or engine temp sender
Altonx
« Reply #2 on: September 06, 2023, 07:40:35 PM »
Not sure cobbadog, like I said I've seen alternators wired directly to this sensor which made me guess its for an ammeter but also tachometers (rev counters) are wired from the Alternator sometimes
dkmc
« Reply #3 on: September 06, 2023, 07:48:03 PM »
I'll wager 20 Attaboy's it's oil pressure sensor or safety switch.
« Reply #4 on: September 07, 2023, 12:38:24 PM »
I would unscrew it to see whats in there but I feel it is a pressure switch.
Diesel Engineering
« Reply #5 on: September 12, 2023, 12:19:50 PM »
It is basically an oil operated switch. Your engine appears to be an AC2W marine engine. This switch was used to energise the charge alternator whenever the engine was started.
Altonx
« Reply #6 on: September 15, 2023, 02:49:57 PM »
Top man, Thank you
