engine date
(1/1)
petert:
Hi, everybody , i have just got a lister D engine , i know very little about them it would be nice if i knew its age the numbers are i/49296 spec 28 DH , it wasnt running a valve had stuck open , its in bits just now i am going to bring it up to standard if i can , it needs a big end shell d19 g bv stamped on it , any advice would be welcome thanks also having trouble removing the peg so i can remove flywheel :-\
petert:
Thanks folks :-[
38ac:
Sorry that nobody answered quick enough to suit you,,,
The serial number you provided doesn't jive with my list that states Lister D production started in 1926 with serial number 80000?
Stationary Engine Parts in England would be the first place I would check for a bearings or other parts but I am in the states. There is very likely other sources of parts that I don't know about.
Removing the Gibb key,
I am not really a "Do a search" type of person but two finger typing large replies on a phone isn't my idea off fun either. There are many artickes and posts on the web available to you by typing in a search. All in all if there is no pressing need to remove the key and flywheel it is best to leave it alone and work around it.
