Author Topic: startomatic control box  (Read 7531 times)
Jase1988
« on: August 21, 2023, 07:05:27 AM »
hello i have two lister startomatic control boxes. one is in good shape and less complicated than the other as in does not have the large capacitor in the center. the other is in not such good shape but has the large capacitor in the center  and two extra metal fin type things. my question i obviously i want to use the good one. so are the diffrences in boxes just diffrent years of production and will either of them work? i have seen on google images there are two diffrent boxes.. many thanks Jason.
Re: startomatic control box
« Reply #1 on: August 21, 2023, 08:43:01 AM »
Hi Jase, yes there where a lot of different SOM control panels. The very early units had selenium rectifiers/diodes/capacitors and large mechanical relays, as technology improved Lister started using printed circuit boards and modern silicon compomponents. Please post a couple of photos of what you have so we can give an assessment of their suitability. It would also be useful to have some idea of what you are trying to achieve.
Jase1988
« Reply #2 on: October 12, 2023, 02:19:14 PM »
Hi Bob thank you for your response sorry im only responding now. the control box is for LD1 startomatic. im struggling to upload pictures could you pm me your email i can send you some pictures. id really like to get the som control box in operation
regards Jason
oldgoat
« Reply #3 on: October 13, 2023, 02:29:32 PM »
If my memory is correct the LD1 is for 12v operation and others are for 24 v usage I can send you a circuit if you PM me with your email
Jase1988
« Reply #4 on: October 13, 2023, 02:43:19 PM »
jbashfield
« Reply #5 on: December 16, 2024, 12:06:50 PM »
Hi , I am having trouble with my SOM on a 1975 Lister 6KV gen set. The engine runs and starts fine with the solenoid override pin in, but when I turn of the mains power I do not hear the main replay click on to try and start it. I have replaced the override micro switch which in the past has proved to be a problem, anyone know of any trouble areas to look at? thanks for your help
