Thanks
Yes, I did find a (relatively) in-Country supplier who had some old stock, from obsolete gasket kits, floating around.
The conical rubber seals never did have an individual part number, apparently, which makes ordering rather challenging!
The local dealer was very helpful. Apparently, on the early engines, Lister originally intended to run the waste fuel out of
the top of the injector, rather than the side opposite the HP inlet. Neither of us understood how this would have worked
mechanically, given that is where the injector clamping bar sits.
Regardless, it is rather odd that the spacer at the top of the injector wasn't replaced by a solid, or capped-off unit and their
rather dodgy solution, was to simply bung a conical rubber seal in there to fill the hole and hope for the best
Certainly, something for HR series owners to keep an eye on, especially if running gravity-fed/elevated fuel tanks.
When these seals start leaking, very bad things start happening..
Richard
