Author Topic: decarboning....how to?  (Read 192 times)
Powdermonkey
« on: May 17, 2023, 11:35:07 AM »
Hi Folks- I'm just completing the 1,000 hour rebuild on my twin 16/2.  It's been running well, thought I want to KEEP it running well.  Rehoned the cylinders, new rings, and decarboned the head.  Mind you, the carbon buildup on the exhaust side (both heads) was...a good bit.  Not insurmountable, but still a good bit of work.  I suspect the standard mufflers are likewise "coked".
So, the question:  Other than mechanical abrasion (scraping), is there a better/easier way to decarbon the entire exhaust port AND mufflers?  I'm thinking of trying a pressure washer...anybody got experience here?
dax021
Re: decarboning....how to?
« Reply #1 on: May 17, 2023, 08:21:24 PM »
If Glort was still around, I'm sure he'd tell you spray some water down the intake manifold while running, but I've never tried it.  From what I've read though, it works.
Hugh Conway
« Reply #2 on: May 17, 2023, 10:30:59 PM »
Hello Powder
I have 3000 + hours on my 6/1 listeroid. Replaced a couple of head gaskets early on before figuring out that the liner protrusion was excessive. Fixed it with a file. Other than that and regular oil changes, no maintenance seems to have been necessary. Still starts an runs as it did way back 12 years ago.
I do decarbonize once in a while by using a spray bottle. A litre of distilled water sprayed into the intake while running at load seems to do it. Do this a couple times a year. I spray until it just starts to reduce RPM.
 Some operators use a water drip feed or siphon to keep things cleaned up. I find that my wife's garden hand spray bottle works just fine.
As always, YMMV
Hugh
1963 BMW R-27 project
Powdermonkey
« Reply #3 on: May 17, 2023, 10:36:25 PM »
Hugh- Do you take off the mufflers when you do this?  Judging by the amount of carbon I "mechanically abraded" from the exhaust side of the head, I'd think it would clog up a pepper-popper muffler....
Hello Powder
As always, YMMV
Hugh
Hugh Conway
« Reply #4 on: May 17, 2023, 10:59:32 PM »
Hello Powder
I do not have a pepper pot muffler installed. The exhaust is a 2" steel pipe that goes into a "Pit-of-Doom" underground chamber. I have removed the pipe at the exhaust port a few times for other reasons, and found no great carbon build-up.
An air compressor filter/silencer is used on the intake. I just unscrew that and spray water directly into the adapter on the cylinder head.
Do a search of the site, you may find info re what others have done. I'm just one guy out in the boonies!
Hugh
« Reply #5 on: May 17, 2023, 11:07:46 PM »
Water injection will only clean up the carbon deposits in the cylinder, it won`t do anything for the exhaust ports and muffler. I have never found anything that will clean the exhaust ports other than elbow grease, I doubt that a pressure washer would work but give it a go and let us know. The deposits in the muffler happen because these slow speed engines don`t get the mufflers hot enough to burn off the deposits. If you have a wood burning stove chuck the mufflers in and leave them overnight, the carbon will burn off them, sadly, so will the paint so you will need a can of high temperature spray paint. A blow lamp will do the same thing, I have used this technique many times on mufflers off 2 stroke engines which also have a bad habit of coking up.
