Author Topic: I need help getting pulley off of a Mecc Alte  (Read 15244 times)
Re: I need help getting pulley off of a Mecc Alte
« Reply #15 on: April 20, 2023, 01:03:07 AM »
I'm guessing you are in the US or Canada based on the Craftsman wrench. Grainger(expensive), Zoro, Motion Industries, or any of the like industrial suppliers. If you can figure out which bushing part number you need you can try Ebay as well. Lots of new old stock and surplus parts there for dirt cheap.
« Last Edit: April 20, 2023, 01:08:50 AM by broncodriver99 »
« Reply #16 on: April 20, 2023, 01:08:23 AM »
Oh, and Congrats!
I would recommend replacing both pieces that way you can be sure they are matched. Also, if you look at that PDF I linked you will see they make assemblies that are designed to go on in the orientation yours was but are removable without brute hammer force. Unless, if you have enough room to align the generator and engine in a manner that will allow you to use a standard bushing and pulley which will likely be cheaper and more readilly available. How long is the generator shaft that you have to work with?
« Last Edit: April 20, 2023, 01:10:14 AM by broncodriver99 »
