Hi Chris
Welcome to the forum.
if it's possible remove the air filter, turn the engine over and squirt a large portion of WD 40 in the intake with the engine decompressors engaged. if you don't have decompressors (i'm not familiar with your engine) turning by hand is best, if you use the battery / starter there's a good chance she'll fire up and run on the WD40.
Seal off as many of the pipes that you have removed and keep them in a clean dry place, then more importantly, seal off any openings in the engine that you have created.
Release the decompressors, if appropriate, and turn the engine until it stops on a compression stroke, at least one of the cylinders will be shut off from the atmosphere. Then seal the air inlet AND the exhaust - ram a rag up it, but leave it close to the outside as a 'tell tale' for the day when you restart.
Disconnect the battery, if the barge is still afloat get a couple of old anodes (appropriate for fresh or salt water, depending on your berth) and hang them fore and aft, earthed to the hull (assuming it's made of steel / iron!) doubly important if you're moored alongside a steel jetty / pontoon or sheet piling. Don't Leave the shore power on when the barge is unattended, stray currents can cause havoc even with decent anodes fitted - ask me how I know.....
There's almost certainly more, but that'll help some, good luck with the refit.
