Author Topic: LPWS Crankshaft bolt reverse or normal thread see photo  (Read 750 times)
SiFi
« on: December 19, 2022, 11:40:03 AM »
I don't want to over-tighten, water pump end!
SiFi
Re: LPWS Crankshaft bolt reverse or normal thread see photo
« Reply #1 on: December 19, 2022, 11:55:19 AM »
OK the engine turns over clockwise in the pic, so I'm assuming the bolt thread is normal...
Diesel Engineering
« Reply #2 on: December 20, 2022, 01:33:32 AM »
The crankshaft pulley retaining bolt is left hand thread..
SiFi
« Reply #3 on: December 20, 2022, 09:42:34 AM »
Makes all the difference to know, thanks
SiFi
« Reply #4 on: December 21, 2022, 09:20:08 AM »
All is good, with 6ft scaffolding pole I was able to undo the left-handed retaining bolt on the bottom pulley. Have had the pumps out, freed the two that were jammed and all back with a governor rail that now freely moves back and forth. As I say a good day!
Diesel Engineering
« Reply #5 on: December 21, 2022, 10:08:40 AM »
Glad you've freed up the pumps and got things moving. Just thought I would post this small section from the manual as it is important for the correct and smooth running of the engine. The diagram shows a special Lister tool, but it is not needed as I'm sure something could be made to do the job. The important thing is that the rack is held at  55.5 mm when the pumps are fitted.
« Reply #6 on: December 21, 2022, 10:11:33 AM »
No attachment to the last post Diesel
Diesel Engineering
« Reply #7 on: December 21, 2022, 10:13:45 AM »
For some reason not being allowed to upload a screen shot to go with the post.
SiFi
« Reply #8 on: December 25, 2022, 12:18:46 PM »
Thanks for the reminder about the rack position.  I had removed the spring and had the rack at maximum position, need check that this is at 55.5mm.
