Cheers for the PDF, I figured I'd go a little deeper and begin to find more identifying marks.
I drained the oil, unfortunately this engine is a bit of a mess. Each bolt is rounded, inconsistent or loose.
All sealing gaskets are far gone and have sealant applied.
The valve/rocker cover has been cracked right open with something heavy and had body filler applied...I may source a replacement but it'll do for now.
The fuel tank is wrecked, it's totally rusted and full of sludge. I think it's split too. Fuel bowl isn't much better, it's heavily pitted but I've cleaned it out for now.
Looks like the fuel filter and tank are the same between the models so I've ordered those parts.
The cams themselves look in good condition, so that's something positive and it seems to have compression.
I did manage to find the cam serial, however this doesn't match any of those from the PDF which leaves me scratching my head a little.
The fuel pump serial could possibly match a LD1 from the PDF? It's a partial match, at least.
Not really sure what to do next. I guess I have to go further and take out the injector?
I'm assuming the oil that goes in these is 10w-40 from some of the reading I've been doing, correct me if I'm wrong.
