Author Topic: Governor rocking  (Read 636 times)
webman
Governor rocking
« on: December 10, 2022, 11:12:31 AM »
Hello folks!
Is there a fix for rocking/jerking governor?
Here is a video that i took: https://youtu.be/c-YInSJNz2w
What could be causing this? Something to do with weights maybe?
Thanks!
Something to do
Re: Governor rocking
« Reply #1 on: December 10, 2022, 09:32:37 PM »
Two things come to mind, one being an irregularaty in the ring on the camshaft where the weight levers run. Its supposed to have a pin in it that prevents it from rotating but possible the pin wore out or fell out. Also could be the weights hitting the lifter bushing closest to the gear. Either can be checked out by removing the crankcase door and shining a light up there while turning the engine
webman
« Reply #2 on: December 13, 2022, 05:27:51 AM »
Thanks for your input!
This makes totally sense. I'll have to take a look.
