Hi Butch, That liner job is going to have to be redone, it could drop into the sump causing god knows how much damage. If those are 1/8" liners then at 5/32" you are only going to have about 30 thou to bore out. That would allow for a 15 thou shoulder near the bottom to stop the liner dropping. You are probably going to have to turn a corresponding shoulder on the bottom of the liner, so the last 1/4" is 1/8" wall thickness. Failing that, some Indian Listeroids have wet liners, you might be able to use one of them.
Finally a bit of good news with the valve seats, strange how some of the work done to this Lister is top quality and some so poor. Time to blame the apprentice?
