Nothing goes easy with this engine. installed the cam and lifters, no biggie right? Not on this one. After everything was in place the governor weights were hitting the end lifter bushing, grrrr
Had to make a custom shim for the far end to push the cam away from the bushing. Next bad news was the sleeves. Ordinarily I use 1/8 wall sleeves which are a stock item at around $100 each. Since the guy before me screwed up the blocks I had to go with 5/32 sleeves which are custom order and $352 each AND 10 week wait.
Just a note to anyone who works on a twin and takes it all the way down. The oil manifold and line that line that runs up to the pump are installed FIRST, or you will be disassembling to get it installed. Just had a phone call last week, "hey, how do you get the oil line in the block and tighten the nut???
Answer, remove the crankshaft, camshaft, then install the line.
