Author Topic: Changfa ZS1115GPM build date 2005 engine number 605100040  (Read 18980 times)
markymark
« on: November 12, 2022, 07:20:43 PM »
Hello guys  ,new to these forums
Have been asked to get this unit running  if  possible
estate    owner   states that  it  has  not run  much
It has electric start
Would like to get it going .
Would one of you fellows have a guideline that I can follow to get  her running
I have contacted Changfa  (China) for parts  (gas filter,oil filter)  but  not too much   info from them
Is there someone in Canada or USA  that has parts
thank you  for your time
Mark
Re: Changfa ZS1115GPM build date 2005 engine number 605100040
« Reply #1 on: November 12, 2022, 08:19:23 PM »
Welcome to the LEF. Information and parts is pretty sparse here in the states. I have the fuel filter in stock that fits most of them. Masters Farm Supply in Fla. has a few parts. https://mastersfarmsupply.com/. Each engine was delivered with a spare parts kit and manual, see if you can find them.
 You can get anything you need through Alibaba.
Other than an operators manual there is little how-to literature that I am aware of. If it has been sitting a while it is possible that the pump and/or injector will be stuck.
Without writing a book about it the basics are this.
 To start it you will find a lever on the valve cover that is the compression release, ooen the throttle an bit. Spin it over and while spinning throw off the compression release and it starts. If not yoy either have compression problems or fuel delivery problems.
keith71
« Reply #2 on: November 12, 2022, 08:30:44 PM »
Hi, The actual manufacturers of these engines in China will probably not respond to parts requests.. But there are many part's suppliers in China that will take an order and send them to you.
Here is one part supplier who seems pretty good (have not ordered from them but have emailed them and they are quick to respond and helpfull)  https://www.wsepo.com/collections/1110-1115-1120-l20?page=1
There is also aliexpress  (a chinese ebay type site) There are most parts listed on there if you search.
There is also yoycart.
I have found most places in this country U.S. that may have once supported these Chinese watercooled diesel  parts are long out of stock. A filter maybe..  Wsepo will have everything you need. And they are a dedicated engine parts supplier. Aliexpress and yoycart carry shoes to engines.
« Last Edit: November 12, 2022, 09:13:57 PM by keith71 »
12/2 Field Marshall
Jiangdong R170.
keith71
« Reply #3 on: November 12, 2022, 08:32:02 PM »
Alibaba is a good place to buy parts if you need 50 of the same thing imo. There shipping is expensive from what I have seen.. Or you will pay alot more if you do not. As 38ac said you can get anything there though..
« Last Edit: November 12, 2022, 09:02:58 PM by keith71 »
12/2 Field Marshall
Jiangdong R170.
keith71
12/2 Field Marshall
Jiangdong R170.
« Reply #5 on: November 12, 2022, 09:29:31 PM »
Another parts source is Made-in-china .com. I needed a starter for my 1115 and quickly found a knowledgeable supplier that quickly shipped me one.
markymark
« Reply #6 on: November 20, 2022, 05:11:18 PM »
markymark
« Reply #7 on: November 20, 2022, 05:14:02 PM »
Thank you for info  guys            Got  it  started
my next step is  to  see is the  generator  side is ok     Found a  Mouse   condo  inside
markymark
« Reply #8 on: December 09, 2022, 05:01:29 PM »
hello
when the tank runs dry
or filter change    do we have to bleed the  injector.
and if so
best  way by  injector feed or  return
thank s.
