Author Topic: Resurrection of a Deutz MAH 914, 1952? Lets see!  (Read 16581 times)
sirpedrosa
Re: Resurrection of a Deutz MAH 914, 1952? Lets see! MAH 916
« Reply #255 on: May 30, 2023, 05:00:11 PM »
Hi Ian
First things first. put pictures as many as you can!
Shims: My 914 has 3*0,25mm (only after running you can identify the knock - the few more knocking aka too early, the more lacking of power)
Dumping fuel: with injector out, turn crank to TDC (You can put a comparator with stem in bore to measure distance versus fly angle) [couldnt find angle of fire Before TDC]. YOU CAN DO IT WITH VEGETAL OIL FIRST.
Steel washer? where?
Just my thoughts for now.
By order of firing up:
iff7378
« Reply #256 on: May 30, 2023, 05:37:12 PM »
My injection pump had a steel washer along with shims behind it but the ring was badly bent and the shim paper falling apart.
Does your pump only have the 3*0.25mm shims between it and the face it mounts on? My flywheel has an F stamped on the rim indicating TDC and the manual states the injection point should be 15 degrees +/- 1 degree.
I'll get some pictures on here soon! This one is staying the natural patina so don't expect flashy paint jobs!
sirpedrosa
Re: Resurrection of a Deutz MAH 914, 1952? Lets see! IP of MAH 914/916
« Reply #257 on: May 31, 2023, 09:54:50 PM »
Hi Ian, Gentles
Lets see the IP cam lobe bump: go here: https://listerengine.com/smf/index.php?topic=9555.msg109890#msg109890
As you can see lobe lift is 10mm. Therefore (now go here: https://listerengine.com/smf/index.php?topic=9555.msg109994#msg109994)
You must see if the travel of plunger is too far (you can take off IP valve [with IP snugged in place] and with the comparator see how much the travel is). If no shims you can eventualy damage pump element and plunger.
And yes all shims are between IP tappet guide face and IP face. Caspici?
I put back all paper shims it had, but if I notice it must be fine tweaked ill make more of 0,25mm gasket paper.
About fancy painting it's just a matter of each country evaluation. Here if I present an engine restored with patina is only a piece of junk.
Remember those engines are low compression, therefore they need starter cigar.
« Last Edit: May 31, 2023, 10:11:41 PM by sirpedrosa »
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? Lets see! ANOTHER TOOL SAVED
« Reply #258 on: June 16, 2023, 10:02:16 AM »
Gentles,
Another tool to the shop. A FIAC compressor from 1988 (turned to nice blue).
Derusted, new paint, new rings from Greece (!!!), new safety valve, new hose connectors... and voilá!
Pic Before and after.
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? Lets see! READY TO RALLY
« Reply #259 on: June 29, 2023, 10:41:10 PM »
Gentles
Next last weekend of July we have the anual craft, culture, and heritage fair at village, therefore I have no time to put the "decent" fuel tank on the German.
So I spoke with chinese and they sent another 1L tank to put on to make the rally.
Take a look how it fits nicely.
2 pics for the show.
« Reply #260 on: June 30, 2023, 07:32:37 AM »
Hope your festival goes well. I would consider a paint job on the plastic tank o make it look as if it is metal or same as th engine. You have done a wonderful job on your German and has been a pleasure to follow the progress and the dedication to making it perfect again. Well done  VP!
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? Lets see! ULTIMATE PREPS
« Reply #261 on: July 02, 2023, 03:29:14 PM »
Gentles
As usual first word will be addressed to all members of LEF, that are with me since the beginning, a special thanks.
Some steps back were supported for them, as you all said thing are always this way, and I must embrace things as they show and give my personal touch in order to achieve my goal (this one is for you Bob, with a special hug).
Cobba, another hug for you, just because you can see the aim of my tasks, and comprehend the world is not square. And no, the 1L tank will stay as it is.
Willw, thanks for your appreciation.
Stef, you still want I present a restoration of a Famel Zündapp, isn't it? Forget, its too expensive!
Butch, look at my German, its fancy, isnt it?
Joks done. Lets go to the business!
Gave a long run to the German (+20mn), let it burn till water gets hot, tweaked governor to 1000 rpm - and no leaks. Open crankcase to see if all is ok, and it shows a nice chamber.
See vid here: https://youtu.be/kJzUZHobpiY
Cut elbow from hopper lid and extract remains of iron from threads with high amp weld rod, and handle saw. New paint, and voilá!
Some pics of process.Forgot to make some pics, but you will all understand.
« Last Edit: July 02, 2023, 03:31:33 PM by sirpedrosa »
« Reply #262 on: July 03, 2023, 06:32:25 AM »
What a beauty ! You have made the "German" look and sound better than the ever did, very well done VP.
« Reply #263 on: July 03, 2023, 08:25:38 AM »
+1 Cobbadog, what a beauty! I don`t mind the new fuel tank, it would look better with an original tank but I doubt anyone could supply one. So the best option is for something functional but clearly not original.
I hope the visitors to your festival appreciate how much work, money, talent and effort went into restoring your engine, it is a credit to you, your family and your community. Well done VP
sirpedrosa
Re: Resurrection of a Deutz MAH 914, 1952? Trolley king pin
« Reply #264 on: September 21, 2023, 12:57:20 AM »
Gentles,
Slowly back on track, Im assembling The German trolley.
Today manage to assemble the king pin, it ends up to be a expensive bit because machinist labour is expensive.
It's perfect, just as I had designed.
Take a look.
PS: Bob answer please to my question at my Petter thread.
« Last Edit: September 21, 2023, 01:04:23 AM by sirpedrosa »
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? Trolley is getting up!
« Reply #265 on: November 06, 2023, 09:28:53 PM »
Gentles,
A few more tweaks on the trolley.
« Reply #266 on: November 10, 2023, 10:29:16 AM »
VP, once again your attention to detail is at the top end of perfection and fitting to the quality finish on "The German". Your king pin design is exceptional so much so I will not post what I recently did on a transporter only a description. 2 flat 5mm plates greased in the middle and a 20mm bolt through the lot from axle to cross member of the trolley.
If a pic is required unfortunately cannot obliged because we are on an extended holiday in our caravan until near Christmas. No pics of the toys with me, sorry.
sirpedrosa
Re: Resurrection of a Deutz MAH 914, 1952? More trolley!
« Reply #267 on: November 12, 2023, 10:45:27 PM »
Gentles, Cobba
A few more pics of the king pin and axle pivoting with silent block.
Primary paint done.
Silent block is a bit of radiator hose 18mm OD, and 12mm ID. Enjoy!
PS: managing to twist the 2 iron bars 40mm*6mm, to attach the pull bar.
« Reply #268 on: November 20, 2023, 10:09:15 AM »
It's been a little while since I have visited hyere as we are still wondering around our great State towing the caravan. The progress you have made is brilliant as is your design, well done.
look forward to seeing more in the near future.
