Gentles
After a work day nothing else better than some yoga by the German.
Give some heat to piston with hot air gun... and
voilá pin slipped like butter. well not quite!
I put all piston rings aligned at 180º from each (with gap by OD of pin), and oil ring by the pin to avoid any force on the ring tips. (Please tell if this is the right way).
Snug large end and give a few rotation and take cap out to see if everything was ok. put back cap.
Made a small oil sump (brake spray cap) and fill with oil, and give several rotation to crank, to put pressure at oil pump. As you can see it drips nicely.
Piston course at honed liner looks sweet!
Things look to come together.
A few pics for the audience.
