Gentles
Give flys extractor a side strategic approach in order to be able to screw the union fastener. Nothing fancy, just a tweak.
The UPN beam start to left the straight line (elasticity) and after I give a moderate heat at the fly boss.
Some drops of WD40 to soak the rust... and a several vigorous hits with wood mallet (with hands, off course) in order to send vibrations thru cast iron.
Off course I only unscrew crank nut 1 turn (otherwise it will fly to Tasmania.
). when it breaks rust it slams at nut.
My friends there was huge energy stored... it clacks hard against crank nut (I learn this one with Squatch253. See here:
https://www.youtube.com/c/squatch253;
Now some pics for the show, by order:
1 - measuring straightness of the jig, in order to put equal force on both sides;
2 - heat, with my 1L torch;
3 - rotating and slamming evenly the fly (Alu can is to protect rod pitch);
4 - Fly is free;
5 - Flys are out;
6 - Crankcase free of flys;
To be continued...
