Author Topic: Resurrection of a Deutz MAH 914, 1952? Lets see!  (Read 142728 times)
sirpedrosa
« on: August 01, 2022, 08:13:47 PM »
Gentles, distinguished forum members
As promised, I now start the topic about the Deutz MAH 914.
But first things first, the Hilux water pump seized a ball bearing, and so it took the opportunity to change the timing belt as well.
The pallet with the Deutz offset measurements is ready for tomorrow to start lifting it.
Lets see how it goes.
Gentles, please fingers cross.
A couple of pics to joy.
VP
PS: this thread came from this one: https://listerengine.com/smf/index.php?topic=9121.msg109521#msg109521
« Last Edit: August 01, 2022, 08:16:16 PM by sirpedrosa »
By order:
Petter PAZ1 - Jun 1967, 3HP, sn 416xx
Petter PAZ1 - Nov 1979, 425xx [Kristin gen]
Lister CD [355399] 1937 - on the bench..
mihit
Re: Resurrection of a Deutz MAH 914, 1952? Lets see!
« Reply #1 on: August 02, 2022, 07:35:00 AM »
Nice little donk, look forward to pictures of it.
sirpedrosa
Re: Resurrection of a Deutz MAH 914, 1952? Lets go............
« Reply #2 on: August 04, 2022, 02:58:32 PM »
Gentles
Here we go... left home monday evening to village. Tuesday melt the fat, the shovel is not easy to maneuver (especially after 3:30), but could get all space clean... I mean clean with archaeology engineering, as you can see further.
I'll give you a set of 35 pics. There is more but the essencial to joy.
Forgive me just to not have a essencial vid of the extraction of the engine from its shed to the ute;
But younger son was helping, and He was so excited with the operation that he forgot to make the vid... saved by the bell the last pic with Backhoe loader man and owner (one of the girls).
Backhoe loader puted arm from upside down into shed and hooked the harness that I made to toke it out.
Pics are titled by order, please be patient...
1 - Cutting Blackberry bushes - AGAIN...
2 - Starting archaeology... with shovel! 3 HOURS SHOVELING!
3 - First find: exhaust pot and an old oil can. And 3 old piston rings.
4 - Ha, Ha.... the ignition key!
5 - The archaeology pile of dirt.
6 - One fire salamander...returned to the wild (Im very conservative of any animal kind).
Cheers.
VP
PS: The vid of water in sump is displayed in FB, among some pics, and DEUTZ Forum will have a few pics with link to here.
« Last Edit: August 04, 2022, 05:24:14 PM by sirpedrosa »
By order:
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? next 6 pics...
« Reply #3 on: August 04, 2022, 03:07:07 PM »
1 - Another fire salamander...
2 - Half way is done... (the bottom of engine concrete stand already visible)
3 - The exhaust pipe is mine, only mine!
4 - last shovel of rubble... is it?
5 - Laid to the pile of rubble.
6 - Now what's next? Got torch and ATFCetone... hummm!
By order:
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? more 6...
« Reply #4 on: August 04, 2022, 03:51:15 PM »
1 - HUau, 1st nut off...
2 - Ok, a break to confirm originality. Label with cast iron!
3 - Afternoon (and after dinner is twice sacrifice, but it must be done. Look at the shirt!). Only could save half of the fuel tank... but banjos are there. Do you get me?
4 - Surprise, surprise... engine has a mold of concrete around the sump. Let's go to primary and get masonry tools... heavy mallet and spick to break it free. (there is the answer why it still here! and not stolen... to scrap).
5 - The last one (nut) had to make his point to be the SOB. Pipe wrench is always the solution to those are stubborn!
6 - Now the SOB is out out of his bed... some pieces of rubble under sump to confirm it stays as it should, to extrat.
« Last Edit: August 04, 2022, 03:53:18 PM by sirpedrosa »
By order:
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? More 6 pics
« Reply #5 on: August 04, 2022, 03:57:37 PM »
1 to 5 - detail pics of the german beast.
6 - Me, one of the sisters, and the loader man after putting it on the Hilux.
« Last Edit: August 04, 2022, 04:01:00 PM by sirpedrosa »
By order:
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? More 6 to joy
« Reply #6 on: August 04, 2022, 04:28:28 PM »
1 - The grave of an engine... Who knows?
2 - All stuff and tools on board to the road...
3 - After 2h (170km) arriving at the stationary engine clinic!
4 - Let's see the how is the inside body, on open the crankcase door? Last nut... Hummm oil and water!!!!! STOP, STOP! Open the sump drain bolt!
5 - About 1/2 dozen liter of water inside! (SEE VID AT FB (STATIONARY ENGINE ENTHUSIASTS); https://www.facebook.com/100001713712882/videos/pcb.5779948948703339/993367731335776
6 - the inside has a good look... Id like to see the same outside..... But time and weather is ruthless!
« Last Edit: August 04, 2022, 05:11:57 PM by sirpedrosa »
By order:
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? Last 6... But not the least!
« Reply #7 on: August 04, 2022, 04:55:55 PM »
1 - Crank and rod looks ok... because oil was above water.
2 - Injector clip is out... but injector body is stuck.
3 - Pulley off;
4 - Crank boss off;
5 - Fuel filter assembly off;
6 - Hopper lid to tank colling off.
By order:
« Reply #8 on: August 04, 2022, 11:36:41 PM »
Well done VP, you have been very busy. Looks like the makings of a very good engine, You may need to buy it a new fuel filter!
sirpedrosa
« Reply #9 on: August 04, 2022, 11:40:14 PM »
Hi Bob, Gentles
Only a fuel filter? Im afraid of the injection circuit; pump and injector.
Two valves for shure.
Hope not to send it to scrap.
VP
By order:
« Reply #10 on: August 04, 2022, 11:48:08 PM »
Nicely done! Looks like the prize at the end was well worth the effort. Looking forward to seeing if you can bring it back to life.
« Reply #11 on: August 05, 2022, 08:43:34 AM »
Hi VP, I would not be too worried about the fuel pump and injector, the rust will only be on the outside. The internals may be seized up with evaporated diesel but should be OK. strip them from the engine and soak them in a mixture of diesel and Automatic transmission fluid for as long as you can, if you can heat the solution even better. Don`t heat them on the kitchen stove, you will get in trouble and probably burn your house down. Try to find a small gas/electric stove or use the barbecue.
Valves should not be a problem, there are sure to be equivalent valves used in more modern engines. How do the valve guides look? You can always ream them out and use a slightly larger valve stem, not ideal but ok if it is only going to be a working display model.
Very jealous of your find, nothing like that in Tasmania.
« Reply #12 on: August 05, 2022, 12:08:30 PM »
Well done on the recovery og this special little engine. You may be surprised at how little it will need to run again. As stated, what it looks like on the outside may be bad but inside still good. Thanks for the pictures.
sirpedrosa
Resurrection of a Deutz MAH 914, 1952? More bits out!
« Reply #13 on: August 05, 2022, 06:17:16 PM »
Gentles,
Another day fighting stress (I mean wrenches and hamer).
Pics by order:
1 - Deutz won a new tool... a braker bar.  ;D ;D ;D
2 - Engine choose: Nut or stud? either!  ;D ;D
3 - Doesnt mater... head is off
4 - Push rods are off;
5 - Piston crown looks great, genuine part, and dated 9/86;
6 - Liner looks great
By order:
sirpedrosa
« Reply #14 on: August 05, 2022, 06:28:53 PM »
Another half dozen:
1 - Rocker assembly with improvised (on the fly) flat wrench tail;
2 - tail detail...  ;D ;D
3 - Rocker assembly off;
4 - Exhaust valve circlip (exhaust valve has a greaser, so wasn't stuck);
5 - All bits recoverd;
6 - Comparing Deutz valve with Lister valve;
By order:
