Hi Guys, I hate to be a naysayer but what is the point? You are going to have to go through all the effort of filtering, de-watering and centrifuging your waste oil. You are then going to burn it in your Lister to produce electricity, which you are then going to use to heat sand or something similar.
Why not cut out all the effort and inefficiency not to mention wear on your Lister and generator head by building a smudge pot oil burner? They are easy to build, they will burn untreated oil and produce enormous amounts of heat. You could always encase the flue in some sort of thermal mass if you want.
Hi Bob,
The Lister is already there. It sits idle waiting for a power outage, I don't see using it for garage heating and greenhouse lighting as a bad thing.
There is NO WAY I'm going to build an oil burner to leave in my garage unattended. I don't trust my Oil Burner building skills enough to go down that road which would also require chimney holes and stove pipes cut through the roof. 99% of the DIY oil burners I have seen on YouTube would never pass any kind of safety regulations.
Also, my wiring and cooling system is already in place. All that's needed is a sand reservoir and some electric elements.
The system I am pondering uses my operational machine that all is ready to go.
If I wait for power outages to use my system, it may still be like new 20 years from now
so it could now earn it's keep by offsetting the current heating costs.
And when winter temps here in Canada dip to -25C, it could make a substantial difference according to my calculations.
Using the cooling system, generator (sand heat) and possibly capturing some exhaust heat in a heat exchanger, the system may approach 70% in thermal efficiency.
This project does require further research and it would not be difficult to program a model where different amounts of sand and different bed temperatures can be tried in order to get the optimal reservoir size.
If the res is too big, the Lister has to run too long to get it up to temperature.
If it's too small, the res looses most of it's heat too soon causing excess engine run cycles.
So the goal here is to have the Lister run 4 hrs in the AM and 4 hrs in the late PM.
Who knows, maybe the model will show that the number don't work. But if they do work, I am interested to build it.
