Author Topic: Ac1 conversion  (Read 179 times)
Waxel
Ac1 conversion
« on: May 02, 2022, 04:17:48 PM »
Hi, i have an ac1 generator with manual start handle. I'd like to covert this to electric start but would need to replace the flywheel with a toothed one. Has anyone done this or know availability of toothed flywheels? Thanks
Diesel Engineering
Re: Ac1 conversion
« Reply #1 on: May 04, 2022, 01:57:42 PM »
The other option would be to buy a starter ring and machine flywheel. That is unless the flywheel has already  been machined to take the ring. I can't remember for sure if all flywheels were machined or not.
Hugh Conway
Re: Ac1 conversion
« Reply #2 on: May 04, 2022, 10:16:57 PM »
There's always the old golf cart starter/generator option.
Hugh
1963 BMW R-27 project
Re: Ac1 conversion
« Reply #3 on: May 05, 2022, 11:50:57 AM »
Don't know what part of the world you are in but currently on US EBay there is a listing with two AC1 electric start engines for $300
Waxel
Re: Ac1 conversion
« Reply #4 on: May 05, 2022, 02:18:49 PM »
I have a starter motor that should fit. The flywheel is currently smooth. Am concerned that if I machine the flywheel it might cause it to become unbalanced
Waxel
Re: Ac1 conversion
« Reply #5 on: May 07, 2022, 02:25:30 PM »
Hugh
Hi, not sure what you mean by this?
Hugh Conway
Re: Ac1 conversion
« Reply #6 on: May 07, 2022, 06:00:13 PM »
@ Waxel
Use the search function to enter "starter/generator", you'll find a lot of links.
Veggie got me inspired to install one  on my 6/1, it works very well, and has for several years of regular use.
No reason it would not work for your engine.
Some examples
https://www.microcogen.info/index.php?topic=3096.0
https://www.youtube.com/watch?v=aS5_sDLmtKs
https://listerengine.com/smf/index.php?topic=7715.msg87443#msg87443
You can find golf cart starter/generators on ebay or maybe locally.
Hugh
Waxel
Re: Ac1 conversion
« Reply #7 on: May 10, 2022, 06:39:21 PM »
Thanks for the suggestions. Much as I love projects, I've already got a list ahead of me that is frightening. Also all the belts and pulleys look a bit deadly to fingers and doggies tails. I'm able to start my ac1 with the manual handle but the wife isn't so a simple starter motor option is all im looking for at this stage.  Maybe even with a 240v battery charger to keep the battery alive... am in Ireland and don't see any cheap electric start ac1s listed anywhere...
Waxel
Re: Ac1 conversion
« Reply #8 on: May 10, 2022, 06:57:02 PM »
Amazingly, have just seen a toothed flywheel on ebay. Does anyone know how difficult replacing a flywheel might be?
Waxel
Re: Ac1 conversion
« Reply #9 on: May 13, 2022, 06:33:18 PM »
That turned out to be a gear wheel of 15cm that I imagine is for engaging with starter handle. Have been quoted €200 for a 20" gear wheel that could apparently be fitted to the flywheel. It's expensive I think and don't even see how it would fit
