Slow Speed Diesel Engines > Red Stone Engines
From the Redstone engine manufacturer...
(1/1)
PhunniPharm:
Dear tks for your response .The JSD1800 and JSD3200 are double flywheel engine, JSD3200 has been stopped a few years ago, JSD1800 has been not produced about 3-4 years, about our sd SERIAL ,the main market is Afghanistan ,but three years ago, the afghanistan market is stead of solar panel ,so the our single cylinder engine business is almost stopped, so, the engine part supplier factories also change the business too, so it makes the supply problem .if you are interesting, i think you can think of LD serial engine, its supply normally some, but i do not know if your way, mentioned air compressor is ok or not when clear the Customs.
