Hi guys
I’m looking for a second opinion on my diagnostics please.
I’m currently working on a CS I bought a while back from the widow of a bloke who collected and “restored” old engines and tractors. It was described to me as a “good runner” and, once I cleaned out all the old gunged-up fuel, it ran fine
The other weekend I hooked up a temporary water supply. I wanted to give it a longer run to get it up to temperature for an oil-change & to tinker with the diesel supply.
I just screwed in some 40mm fittings to the top and bottom flanges with a water feed running in the bottom and flowing open-ended out the top, and a valve to control the bottom flow so the water at the top was coming out warm. I dismantled & drained this when I was finished.
This weekend when I went up there and turned it over backwards to engage the valve-lifter – water dribbled out of the exhaust - just an egg-cup-full maybe.
(Just a note that both intake & exhaust have downward-facing pipe bends so it’s not rainwater). I turned it over a few times, then started it and it ran fine after some initial smoking.
I would guess I have a leak in the head-gasket. I have just now sent off to Gaskets-to-Go for some replacements; and I’ll take the head off for a look next time I’m on site.
I guess it’s possible there is damage to the head or block? I would guess, also, that any running it has done in recent years has probably just been a minute or two – there’s no evidence of any cooling plumbing having been attached to it recently.
Also I have been unable to get it to run properly on the low-compression setting. It starts beautifully on the high-compression, but just smokes and hammers and seems to have only partial compression when the valve is screwed-out. I took the change-over valve out and it came undone suspiciously easily. Looking at it, I think it may have been made up from two mis-matched halves?
I have a new one to fit anyway; but I just mention it in case there’s a history of castings cracking in that area or some such.
I’d appreciate any thoughts. Cheers, Mike
