Author Topic: Lister JP3 16KVA 3 phase generator .  (Read 14278 times)
oldtime
« on: February 21, 2022, 10:01:26 PM »
Hi all anyone got any leads on a manual for the 3 phase Generator ?
 Its all painted Army green !! It starts and runs Well . I need to sort out the Generator end . thanks Mark Canberra Australia
Re: Lister JP3 16KVA 3 phase generator .
« Reply #1 on: February 26, 2022, 10:16:50 AM »
G'Day MArk and welcome to the Forum.
It might take a bit of time but you will get some help from memebers wo know about generators. Also try posting this in the Generator Section of this Forum.
What might help you get better responses is listing some or all of you problems so replies can start.
P.S. We drove through your neck of the woods about 2 weeks back heading to Cooma. Now working our way back north along the coast to home near Taree.
oldtime
« Reply #2 on: February 27, 2022, 10:58:13 PM »
If your ever down this way come and take a look at my workshop . lots of old stuff .
« Reply #3 on: February 28, 2022, 10:06:41 AM »
Thanks for the kind offer. Not too sure when we head South aain but have plans to do so just not sure as to when.
same if your ever up North near Taree call in ad have a look at the varied selection of tous from stationary engines, tractor, small dumpy truck and mowers just for starters.
oldtime
« Reply #4 on: February 28, 2022, 10:14:07 PM »
woo dumpers I have three .. even one made in Australia !
Hope you are keeping dry
« Reply #5 on: March 02, 2022, 05:56:59 AM »
Its still bloody wet here and the grass has grown so long in 3 weeks that the cows down the street are eyeing it all off. Our Dumpy is a Liner Roughrider with a SR2 in it.
iwasleftunsupervised
« Reply #6 on: January 11, 2023, 10:30:43 AM »
I might be able to help you,what is it you're after knowing?
« Reply #7 on: January 12, 2023, 04:45:41 AM »
Hopefully 'oldtime' reads this
oldtime
« Reply #8 on: August 04, 2023, 06:04:18 AM »
i want to know about the rotating voltage regulator . mine is driven by a belt off the crank .
it looks a bit like it doesn't belong there
« Reply #9 on: August 11, 2023, 07:36:56 AM »
They're usually driven from the crank between the back of the engine,and the alternator by a pulley,and belt,and bolted to one of the side rails,or mounted above the flywheel,or driven by a motor usually mounted by the end of the exciter dynamo,anything else bud?
oldtime
« Reply #10 on: August 30, 2023, 06:29:27 AM »
any chance of a picture ? mine is mounted on the side and is a very sad job . I think mine was mounted on top .
I would like to put on top .To tidy up the generator .
« Reply #11 on: August 30, 2023, 10:46:32 AM »
I must admit i've got mine mounted on a display board seperate to the generator,when we're out at shows with it,and use an electronic avr,when we use it back at the yard,but i'll have a look for a picture for you of where they usually go
« Reply #12 on: August 30, 2023, 05:37:29 PM »
Managed to find some better pictures,one of how i've got mine,and a side mounted position,and an end mounted motor driven,can't find any of an Isenthal mounted on top unfortunatly
« Reply #13 on: August 30, 2023, 05:41:04 PM »
Side mount,and end mount
« Reply #14 on: August 30, 2023, 05:41:58 PM »
And how we've got ours
