Author Topic: JP Lister Fuel Drain  (Read 11126 times)
oldtime
« on: February 21, 2022, 01:23:41 AM »
Hi all how does this water drain work ?
 Genuine lister JP3 with generator   16 KVA three phase
 I am also looking for information about the Generator end .
 It has been under a house for the last 20 odd years .
 Got it home on the weekend its Very heavy thinking above two tons .
littleridge
Re: JP Lister Fuel Drain
« Reply #1 on: May 21, 2022, 02:47:58 AM »
Hi,looks like some real bush-craft mate.As long as it don't leak it will do,but not STD factory issue !
oldtime
« Reply #2 on: June 27, 2022, 05:28:19 AM »
no its a genuine Lister bit ..
oldtime
« Reply #3 on: April 06, 2023, 01:48:45 AM »
bump ... still trying to work out this dam tank drain ..
 I belive the voltage regulator has been moved on this unit .somthing is just not right . what a well made gen set in all its drab green
« Reply #4 on: July 03, 2023, 11:53:57 PM »
Looks like a lug nut with a bolt through it, probably got a large washer with a seal inside of the tank. If the threads in the tank nipple are intact you can probably find a suitable drain tap on Ebay.
