Author Topic: SR2 starter replacement  (Read 13081 times)
KC7NOA
Re: SR2 starter replacement
« Reply #30 on: February 19, 2022, 09:15:30 PM »
Diesel Engineering
« Reply #31 on: February 20, 2022, 01:19:13 AM »
The spacer you have is for the 24 volt coaxial starter. For the starter in the photo you would need the thinner spacer. At a guess I would say it is around 1/2 inch thick.
KC7NOA
« Reply #32 on: February 20, 2022, 04:15:29 AM »
24v ... I was trying 12v on the original.
Know a part number of the spacer I should be looking for?
Diesel Engineering
« Reply #33 on: February 20, 2022, 05:43:52 AM »
The Lister part number for the thinner spacer is 202-26550
« Reply #34 on: February 20, 2022, 07:48:16 AM »
Just a stupid yet obvious question. Have you tried your local starter/alternator rewinder? There may not be one in your area but here luckily there are still a couple of old school shops capable of rewinding a starter. May be worth pulling out the phone book and seeing if you have a local rewind shop. Even if worst case they can't fix it maybe point you in the right direction.
« Last Edit: February 20, 2022, 07:50:02 AM by broncodriver99 »
KC7NOA
« Reply #35 on: February 20, 2022, 08:13:40 PM »
It's not the winding that is a problem ... I think the magnetic field has degraded ... the gear is half way out and does not retract from the flywheel.
The starter had probably been overheated and collapsed the power in the alinco magnet.
« Reply #36 on: February 26, 2022, 10:13:13 AM »
2 options in my book, re-instate the magnetic field as you would re-charge a magneto or take you spacer to a machine shop and have it milled down to size.
KC7NOA
« Reply #37 on: March 01, 2022, 08:49:10 AM »
well,
Gary sent me a spacer along with a rocker push rod .. the spacer does not fit my housing -- just slightly bigger. The spacer fits the starter nicely ...
I took the original starter to a shop  -- the owner is 85yrs old and recognized the numbers as a starter from a boat. I'm like, yea .,.. that's a big possibility.
So he said he will return it look and operating like new -- good to me !!!
Honestly, i don't like not having sources for wear parts ... i have no idea how long ago this starter failed -- or why. I hope i can source a spacer for this china clone ...
sirpedrosa
« Reply #38 on: March 01, 2022, 03:36:08 PM »
KC7
go easy. there is nothing that cant be done. Off course it ill coast, but you aim to get it running. Be patient, sort all out to the best solution you can get.
By order of firing up:
« Reply #39 on: March 02, 2022, 06:08:47 AM »
Im back home and have found a manual of sorts but I need to find out how to compress it enough to post on the forum
« Reply #40 on: March 02, 2022, 10:01:11 PM »
@cobbadog
Looking at the manual you provided, I was reminded of a boat I used to have circa 1973.
It had an SR2 rated at 12BHP continuous. On the side of the fuel control was a stop with a lead seal. Breaking the seal allowed the operator to advance the throttle to "WAR EMERGENCY POWER" I never tried that, but the engine could produce that 12 HP effortlessly. The heated air could be ducted to the cockpit and sure kept it warm.
« Reply #41 on: March 03, 2022, 04:52:55 AM »
Nice bit of info there Hugh, It is amazing what can be found out on these Forums.
Will try to load another 2 manuals but one in each post in case it over loads the system
« Reply #42 on: March 03, 2022, 04:56:13 AM »
Sorry the last one I have was titled A25 Lister Air Cooled but must be too large a file.
dax021
« Reply #43 on: March 03, 2022, 05:58:30 PM »
@cobbadog
Apparently Spitfires had a seal like that too.  Break the seal for emergency HP.  Hence the saying "through the wire"  If the plane came home with the wire broken, the engine had to stripped and rebuilt, which apparently pissed off the techies.
« Reply #44 on: March 04, 2022, 05:03:05 AM »
Even more great information. Some Techies are just like big sheilas and whinging about anything that makes them do something for a change.
