Author Topic: Leader 8-1 rebuild epoxy question.  (Read 1231 times)
Tailwheel
« on: November 14, 2021, 09:59:52 AM »
Have this 8-1 bulk stripped ready for rebuild, and asking what type of epoxy we should paint the crankcase internals with?      The casting is usual Rajkot cast, extremely poor, and we believe it was leaking oil through the crankcase, and need to reseal it.
Thanks all,  Tailwheel.
Re: Leader 8-1 rebuild epoxy question.
« Reply #1 on: November 14, 2021, 03:26:49 PM »
I used generic red electrical varnish in a spray can- aka glyptol after a recomendation here from 38ac.  It worked well, provides a smooth surface and was easy to use, and was pretty inexpensive.  5 years on it still looks good.
« Reply #2 on: November 14, 2021, 03:45:04 PM »
yes, as Bruce said this is what I use and reccomemd
« Reply #3 on: November 14, 2021, 07:04:33 PM »
I should add that there is a product made expressly to seal porousity in castings, it is called Dichtol. You don't paint an entire crankcase with it but brush it on suspected areas where I seeps in the flaw and seals it when dry
32 coupe
  • "Doc Johnson" on call !
« Reply #4 on: November 14, 2021, 08:17:54 PM »
When I did my twin I used white rustoleum.
I was not in a hurry so the dry time was no big deal. Nice white background when changing
oil and doing inspections.
It's been years and has held up fine.
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
Tailwheel
« Reply #5 on: November 15, 2021, 12:05:21 AM »
Thank you guys for the heads up, much appreciated.
Tailwheel.
cujet
  • Lister power rules!
    • www.cujet.com
« Reply #6 on: November 15, 2021, 02:39:20 PM »
I used 2 part epoxy primer. It's held up for better than 15 years. It was not cheap, but it was easy to deal with and cured quickly. I think it can be found at marine stores.
