Author Topic: lister cs control box  (Read 402 times)
vegoil
« on: October 08, 2021, 05:40:49 PM »
I need help I need two resistors v10/gh/12 ohm 69a and the large adjustable one both in the box on top of the BKB alternator
dose anyone know where I can get ones
« Last Edit: October 08, 2021, 11:05:23 PM by vegoil »
vegoil
Re: lister cs control box
« Reply #1 on: October 09, 2021, 10:05:43 AM »
I am going to rewind the large one as I have ordered new wire,
I still need help with he small one as I will need to order a new one. can anyone help with identifying the type?
on the side of what's left of it, it is 12ohm but I don't know the wattage dose anyone know what it should be?
« Last Edit: October 09, 2021, 10:55:30 AM by vegoil »
« Reply #2 on: October 09, 2021, 08:15:37 PM »
have you got a schematic for this generator?
any pictures of where the missing resistor fits?
what does it control?  field?  or?
approx physical size?
it shouldn't be too hard to figure out a replacement, but need more information.
vegoil
« Reply #3 on: October 09, 2021, 10:10:03 PM »
it goes inline to the exhaust lifter
« Last Edit: October 10, 2021, 05:42:42 PM by vegoil »
vegoil
« Reply #4 on: October 17, 2021, 10:20:22 AM »
I am back with another problem! Help Please.
It appears that the alternator is overcharging I have rewound the Resistor in the box on top of the alternator. using the hole length of the resistor still doesn't take the volts below 30VDC The amp meter is hard over to the stop about 5 amp but don't know how much more. I don't want to Boil the battery's!
Could it be the rectifier on the end of the alternator? is there any way I can test it. I don't have a wiring diagram for the alternator but I have sent for a lister manual on the BKB 4.5 Kva should be hear in a few days.
« Last Edit: October 17, 2021, 10:32:34 AM by vegoil »
vegoil
« Reply #5 on: October 17, 2021, 03:01:56 PM »
Just to give an update I have rewound the resister in the top box again using 0.6mm mig wire insted of 0.8mm. for the moment all is working. I will keep you posted.
regards
John
