Author Topic: Ashwamegh cooling project  (Read 680 times)
32 coupe
  • "Doc Johnson" on call !
« on: August 29, 2021, 11:16:14 PM »
Finally got back to the Ashwamegh cooling project.  Got the frame built and the honda radiator mounted.
I have used the honda radiators on several projects and they work well. Should be fine on this job as well.
I have the fiberglass panel made to mount the fan but obviously not mounted at this point.
I bought a small circulating hot water pump I will use .
Just thought I'd show my progress.  Should make more headway next weekend.
Enjoy !
« Last Edit: August 29, 2021, 11:18:25 PM by 32 coupe »
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
cujet
  • Lister power rules!
    • www.cujet.com
Re: Ashwamegh cooling project
« Reply #1 on: August 30, 2021, 07:50:00 PM »
Nice frame. I hung my radiator off of my twin via 4 low quality arms, as a temporary way to run the engine. As you'd expect, it became permanent and it's been that way for the last 15 years. Maybe I should fabricate a frame like yours and brace the assembly on the cylinder heads to reduce vibration. Might be a nice project for the fall, after hurricane season is over.
32 coupe
« Reply #2 on: August 30, 2021, 08:07:58 PM »
cujet,
Thanks.
I have 2 braces that run to the threaded holes in the cylinders. Hard to see in the pic but they are there.
I picked up the hose and fittings today. Hope to get back to it this weekend.
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
« Reply #3 on: September 05, 2021, 12:57:10 PM »
Looks like good work to me.  ;D  When I was building up China diesel packages a few years ago I used Geo Metro parts because they were dirt cheap at Rock Auto, radiator, fan, fan control.
Brad Silwood
« Reply #4 on: November 27, 2021, 07:52:57 PM »
Would a larger radiator circulate enough coolant via thermosyphon, without the fan ? Just, cap off ?
Lovson 6/1, 23.5 " spoke style flywheels, has not run yet
Ford Excursion 4x4 7.3 diesel  B100
John Deere 4020  B100
3 Polaris diesel 4x4 ATV's  B100
'85 MB 300D  B100
'82 MB 300D  B100
« Reply #5 on: November 28, 2021, 03:39:40 PM »
Nice work,
Is there a thermostat in your system?
If so, how did you incorporate it?
Veggie
« Reply #6 on: November 28, 2021, 04:52:39 PM »
Nice work,
Veggie
Run some clothes dryer flex duct from the alternator vents to your radiator.  That alternator moves a lot of air !
32 coupe
« Reply #7 on: November 28, 2021, 05:19:31 PM »
I used 2 t-stats.  I used the stock water manifold off the heads. A little grinding with a
die grinder and a couple of home made gaskets.
I am further along now. New pump and plumbing.  I will post some new pictures soon.
Gary
« Last Edit: November 28, 2021, 08:16:54 PM by 32 coupe »
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
