Author Topic: RPM ISSUE ON LISTER CS. INDIA  (Read 1141 times)
Anabiodun
« on: August 24, 2021, 08:15:33 AM »
What can make lister cs engine speed not stable, within the 2 minutes it will high and low it speed. Have check the cam shaft governor, linkage, change the element inside pump, still the the same, pump is creaking.
Re: RPM ISSUE ON LISTER CS. INDIA
« Reply #1 on: August 24, 2021, 11:08:08 AM »
Answering this one question will help narrow it down.
 With the engine running at speed hold the pump rack from moving with your finger. Then does the RPM remain steady?
Anabiodun
« Reply #2 on: August 24, 2021, 01:04:11 PM »
Yes but the speed is high
« Reply #3 on: August 24, 2021, 04:20:11 PM »
You can't slow it down by moving the rack?
Anabiodun
« Reply #4 on: August 24, 2021, 05:35:21 PM »
Yes, it will go off, and initially the lister is misfiring, have increase the pump tappet, cylinder, the piston ring is closed, still the same.
Powdermonkey
« Reply #5 on: August 26, 2021, 04:44:04 PM »
There is perhaps too much slack in the linkage, permitting the fuel rack to wander.  I fixed this issue by drilling a SMALL hole through the end of the fuel rack, on the filter side of the fuel rack.  Placed a SMALL hook-spring through the hole, and fastened it around the filter.  That small spring took up that slack, and prevented the rack from wandering.  Eliminated my rpm wander entirely.  PM me if you'd like pictures.
