Author Topic: BKB CTR 3KVA AC Generator  (Read 668 times)
DavidLees
« on: June 20, 2021, 05:22:58 PM »
Hi. I have recently acquired 3 CS generating sets in various states of repair and am working through them slowly.
First is a 6/1 with a 3KVA alternator which is now belted to the sawbench and runs a treat. It is not a SOM set. I would be extremly grateful for a wiring diagram for this alternator, serial number 41676/1. It has a battery charging output voltage of 38 volts at 3 amps. SOM is not needed with this set, so as simple as possible!
4KVA SOM VA with a sad crankshaft big end is next to be looked at.
Thanks very much.
David.
