Author Topic: Lister clone Powerline 24/2 questions  (Read 1723 times)
93Ford
Re: Lister clone Powerline 24/2 questions
« Reply #15 on: June 13, 2021, 02:19:23 AM »
At this point I'm thinking of using a threaded rod and nut. It would allow it to give more throttle if necessary from the generator and at the same time there is no force trying to pull it raising the rpm so if it is something like the governor springs/weight it should have just enough force to push it up against the nut that will set the minimum rpm. I can't see any reason why it wouldn't work
32 coupe
  • "Doc Johnson" on call !
« Reply #16 on: June 13, 2021, 04:14:34 AM »
Are you trying to set the throttle from a no load to loaded situation  ?
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
93Ford
« Reply #17 on: June 13, 2021, 02:13:18 PM »
 I'm just trying to get it to run at its specified rpm with no load.
32 coupe
« Reply #18 on: June 13, 2021, 06:58:23 PM »
OK, my next question would be what rpm ?
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
93Ford
« Reply #19 on: June 13, 2021, 11:52:12 PM »
Should be 1000rpm or whatever gets the generator to 60Hz
