Lister Engines > Petteroids
Lister Petter LPW3A rebuild
praxidice:
Is there anyone here with experience in dismantling / rebuilding a Lister Petter LPW3A ?
I have a few issues that are not covered in the service manual and would appreciate input from someone who has been there done that.
Presumably all LPW series engines are essentially similar (apart from the number of cylinders), indeed one service manual covers the lot.
mihit:
Not specifically, but I've pulled down more than a few engines.
What are ya after?
praxidice:
Present issue is removing the camshaft.
I've followed the service manual instructions to the letter but the thing simply will not come out
Asked a number of associates with relevant experience and they have no idea
Something must be stopping it coming out but what ?
The camshaft is the last bit left in the block ... no cam followers, no governor components, no crankshaft, no lift pump pushrod
mihit:
Picture speaks a thousand words...
Are you trying to lift it up, or slide it out?
All bearing caps removed? Any movement at all?
praxidice:
--- Quote from: mihit on May 15, 2021, 07:01:17 AM ---Picture speaks a thousand words...
--- End quote ---
Tried both lifting it up and sliding it out
Can't understand relevance of bearing caps, in any case LPW engines don't have conventional main bearing caps
There is a bit of movement, maybe a centimeter, but its difficult to see whats holding the camshaft due to the only access being on the side of the block rather than the bottom
