Author Topic: Museum Lister D problems  (Read 22015 times)
Lcrowther
Re: Museum Lister D problems
« Reply #30 on: November 10, 2023, 10:47:34 AM »
Hi,
It’s been a while since I sorted it. I ended up acquiring it, so it came back to my workshop and I completely stripped it down.
Turns out the piston rings have had it, and there was some scoring of the cylinder.
I honed the cylinder and fitted new oversized piston rings and that seemed to solve the problem and it worked quite happily ever since.
To be honest, I haven’t ran it for over a year so I think I need to drag it out and run it for a couple of hours.
Thank you
Luke
« Reply #31 on: November 10, 2023, 10:50:56 AM »
Thanks for the reply with a great outcome. Yes, once you fix them give them a regular run or you will end up back at square on.
Quite a few blokes out here often have a start up day at home and video them for fun and to share. It is a good feling to see your toys lined up running or misbehaving which ever the case may be.
