I really enjoy looking through the pics of everyone's setup. There are a few of you that are completely over the top, and have some of the most beautiful engine, starter, genny, permanent and mobile installations and belt combinations. I am taking serious mental notes of all your great work, and hope to get my project even "close" to that level.
Luckily, after I used plastigage to check my TDC clearance, I wasn't able to immediately put the head right back on, which was a good thing. I had been doing a bunch of reading here, and came across posts about separated head gaskets causing probs with leaking water. There was talk about gluing the gasket back together, or painting with something - but no definitive answer. I am now ready to slap my head back on, and I do have one of these separated head gaskets. It is 15 years old, but since it was only run at the factory before shipping (maybe), it looks great even though it has come apart. What should I do with it - OR, will 150 ft lbs of torque keep it together ?
My second question is about the spoked flywheels. Is there a right and a left side - or an inside and an outside ?
Lastly for today - What is the absolute best way to hammer back in the gib keys. When do you know that you have the gib set correctly. I do own some powerful equipment that will kill you instantly, and I have SERIOUS RESPECT for, and pay attention when I'm using them. I put these CS engines in this same category. I can't imagine having a 100 pound flywheel coming off and running through a home or a yard, and then the unbalanced engine cartwheeling. It makes me nervous when I watch youtube vids, and guys start these things not held in place and they're hopping around the floor. What do they plan on doing when 600 pounds is running and unmanageable ? I was watching a video of Veggies setup, and I saw just outside his gib key, he had a circular lock of some kind, maybe allen insert set screws. I want a pair of these in addition to the gibs, so if someone has a link to those safety rings, that would be great. Thanks everyone.
